- To: Hugo Herbelin <hugo.herbelin AT inria.fr>
- Cc: Coq Mailing List <coq-club AT pauillac.inria.fr>
- Subject: Re: [Coq-Club] Coq 8.2: Sort polymorphism and the module system
- Date: Sun, 14 Sep 2008 14:19:48 -0400
On Sep 10, 2008, at 06:31, Hugo Herbelin wrote:
The result of a functor
application is obtained by simple substitution of the fields and the
types of the fields in the applied functor are the ones computed for
the body of the non applied functor (independently of whether the
functor body has an explicit type constraint or not). For instance, we
have
Module Type S. Parameter t:Type. End S.
Module F (X:S). Definition t := X.t. End F.
Parameter nat' : Set.
Module N. Definition t := nat'. End N.
Module P := F N.
Check P.t. (* P.t : Type *)
where the information that P.t can be typed of type Set has been lost.
Being able to infer P.t : Set would require in the general case to
recompute all types, as substitution of field parameters by actual
arguments may occur arbitrarily deep in expressions and accordingly
refine non trivially the inferred type of exported fields. Is this
cost worth?
Hoping to have clarified the point,
Thank you. That explanation is indeed helpful.
--Brian
- Re: [Coq-Club] Coq 8.2: Sort polymorphism and the module system, Hugo Herbelin
- Re: [Coq-Club] Coq 8.2: Sort polymorphism and the module system, Brian Aydemir
