- To: Coq Club <coq-club AT pauillac.inria.fr>
- Subject: Re: [Coq-Club] Program Fixpoint, measure, and simplification
- Date: Thu, 18 Sep 2008 09:05:13 +0200
Le 18 sept. 08 à 00:39, Brian Aydemir a écrit :
On Sep 17, 2008, at 16:18, Matthieu Sozeau wrote:
(* too lazy to prove this right now *)
(* as noted below, I don't actually need this lemma for the problem to appear *)
Axiom lc_rename : forall x y e,
lc (open_rec 0 (fvar x) e) ->
lc (open_rec 0 (fvar y) e).
That's why it blocks, at the recursive call in the [lc_abs] case,
you give this axiom which makes reduction stop right after, on a
[match (lc_rename e x0 7 pf) with ...]. You can see that by doing
some unfolding and simplification (and wait a bit because the
resulting term is huge).
Right. That makes sense, and I expected reduction to get stuck there. What confused me is that reduction seemed to get stuck before I reached that point. I'll use the [app] case as an example, since it doesn't depend on [lc_rename]. In the goal, I see
silly_subst x u (app e1 e2) (lc_app e1 e2 pf1 pf2) = app e1 e2
If I look at my definition of [silly_subst], I see that it does a [match] on the fourth argument. The fourth argument here has a constructor at its head, so I expected that the application should somehow reduce to
app (silly_subst x u e1 pf1) (silly_subst x u e2 pf2) = app e1 e2.
Definitions made using measures are structurally recursive on a proof of well-foundedness
of the naturals that's hidden inside the [silly_subst] definition here.
[unfold silly_subst, Fix_measure_sub.]
In the app case, the real argument that is matched is [lt_wf (size (app e1 e2))],
and for some reason, [simpl] won't try to reduce it (probably because it's not seen
as recursive, I'm not sure).
You can try and put it in hnf:
match goal with
| [ |- context C [ lt_wf ?x ] ] =>
let prf := eval hnf in (lt_wf x) in
let gl' := context C [ prf ] in
change gl'
end.
Now you see an [Acc_intro] constructor at the head of the proof so [Fix_measure_F_sub]
can unfold at least once. This time [simpl] will reduce but it cannot do the usual trick
of folding back the fixpoint in the reduced term, as the fixpoint is local to the definition
of [silly_subst]. In this case, I think if [simpl] was called before the unfoldings it would
consider the goal is not in good shape and just fail, making no progress, even if the [lt_wf]
proof did unfold. Even by hand, it's not clear how to fold back the recursive calls at this point
because [simpl] does too much reductions in the [lt_wf] proof and the functional itself. That's
why I use a lemma instead.
It looks like what I want is [fold_sub] and [unfold_sub]. I think was expecting [program_simpl] to do the equivalent thing for this function that [simpl] would do for functions defined by normal structural recursion. (-:
My bad, [program_simpl] is supposed to simplify the goal, by destructuring objects in subsets,
simplifying the correponding projections and the like, not to be a variant of [simpl].
Ltac fold_sub f :=
match goal with
| [ |- ?T ] =>
match T with
appcontext C [ @Fix_measure_sub _ _ _ _ ?arg ] =>
let app := context C [ f arg ] in
change app
end
end.
Is this intended work with my version of Coq ( svn:// scm.gforge.inria.fr/svn/coq/branches/v8.2 , r11417 )? Coq is complaining: "Error: The reference appcontext was not found in the current environment." The syntax is unfamiliar to me, as well.
Indeed, it seems I did not backport this code yet. appcontext is just a variant of context
that allows to match partial applications.
-- Matthieu
- [Coq-Club] Program Fixpoint, measure, and simplification, Brian Aydemir
- Re: [Coq-Club] Program Fixpoint, measure, and simplification,
Matthieu Sozeau
Brian Aydemir
- Re: [Coq-Club] Program Fixpoint, measure, and simplification, Matthieu Sozeau
- [Coq-Club] Type-checking & Evaluation, Thery Laurent
Brian Aydemir
Matthieu Sozeau
