- To: Coq Club <coq-club AT pauillac.inria.fr>
- Subject: [Coq-Club] Type-checking & Evaluation
- Date: Thu, 18 Sep 2008 14:24:17 +0200 (CEST)
Hi,
I'm getting more and more puzzled by Coq behaviour. Here is an
example:
I've a function that is computationally very intensive:
Definition myfun (x: nat): option nat := ..
Then when I do
Eval vm_compute in myfun 1.
= Some 25011
: option nat
Finished transaction in 35. secs
Ok fine, but when I do
Eval vm_compute in (match myfun 1 with Some c => c | None => O end).
This never returns.
Why? Actually this is a typechecking problem: in order to typecheck
the expression, it seems that Coq tries to normalize the term (myfun 10), no way it will succeed without the vm_compute.
Ok my example is a bit contrived. But here is the actual
situation where I got the bug.
I had defined this tactic:
Ltac mytac l :=
let x := eval vm_compute in
match myfun l with
Some c => c
| None => ..
end in
and now while proving a theorem, I call the tactic
mytac 1.
and this loops: the term (match myfun 1 .... end) is created and typechecked dynamically by Ltac :-(
Here is my question:
Is there a real good reason for having this unrestricted normalisation in
the typechecking?
Laurent Théry
- [Coq-Club] Program Fixpoint, measure, and simplification, Brian Aydemir
- Re: [Coq-Club] Program Fixpoint, measure, and simplification,
Matthieu Sozeau
Brian Aydemir
Matthieu Sozeau
- [Coq-Club] Type-checking & Evaluation, Thery Laurent
Matthieu Sozeau
Brian Aydemir
Matthieu Sozeau
