- To: coq-club AT pauillac.inria.fr
- Subject: [Coq-Club] Interaction of coercions and definitions
- Date: Thu, 23 Oct 2008 12:05:06 +0100
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=message-id:date:from:to:subject:mime-version:content-type :content-transfer-encoding:content-disposition; b=rHQblT994syGHweKtyP5Z/vDfnzHINHcj+JXpCyzM+CujN8Qslq1Q6p+O9tcJj8GFK wQMiSdOU0mAnHbGqbI6imnss8Otf72RkpPYykMD6gzJyfkwcvgiXq/TOi9Lf07ih7hvj voGXRYGKYjRkBWoiaLJ1mvRgcOOL51Qi6nsfo=
I'm having some trouble understanding how implicit coercion to Funclass
interacts with definitions.
Here's a small example to illustrate the problem: the aim is to define
the type of equivalence relations on a given type A, in such a way that
if R is an equivalence relation on A and x and y are terms of type A then
R x y is a valid term.
(* Begin script *)
Section Relations.
Definition relation A : Type := A -> A -> Prop.
Definition reflexive A (R : relation A) := forall x, R x x.
Definition symmetric A (R : relation A) := forall x y, R x y -> R y x.
Definition transitive A (R : relation A) := forall x y z, R y z -> R x
y -> R x z.
Record equivalence_relation (A : Type) : Type := {
equivalent :> relation A;
reflexive_prf : reflexive A equivalent;
symmetric_prf : symmetric A equivalent;
transitive_prf : transitive A equivalent
Variable A : Type.
Variable R : equivalence_relation A.
Variables x y : A.
Check R x y.
End Relations.
(* End script *)
Running this under coq version 8.1, the line "Check R x y." fails,
giving the error message:
Toplevel input, characters 22-25
Error: Illegal application (Non-functional construction):
The expression "R" of type "equivalence_relation A"
cannot be applied to the term
"x" : "A"
However, if I replace the line "equivalent :> relation A;" by
"equivalent :> A -> A -> Prop;" then all is well.
The problem seems to be that the definition of equivalence_relation
provides an implicit coercion from equivalence_relation to relation,
but there's no coercion path from relation to Funclass.
How do I declare the coercion from relation to Funclass so that
"Check R x y." typechecks? As a newcomer to Coq, I'm sure
I'm missing something obvious; any pointers would be appreciated.
Mark Dickinson
- [Coq-Club] Interaction of coercions and definitions, Mark Dickinson
- RE: [Coq-Club] Interaction of coercions and definitions,
Georges Gonthier
- Re: [Coq-Club] Interaction of coercions and definitions, Mark Dickinson
- Re: [Coq-Club] Interaction of coercions and definitions, Vladimir Komendantsky
Georges Gonthier
