coq-club - Re: [Coq-Club] Interaction of coercions and definitions
chronological Thread
  • From: "Vladimir Komendantsky" <komendantsky AT gmail.com>
  • To: coq-club AT pauillac.inria.fr
  • Subject: Re: [Coq-Club] Interaction of coercions and definitions
  • Date: Thu, 23 Oct 2008 12:59:23 +0100
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=message-id:date:from:to:subject:in-reply-to:mime-version :content-type:content-transfer-encoding:content-disposition :references; b=R4tPMeDJmP0hbsg3qnTEBwte6RPOg6SVaIMSCmdtZM2lufM77kj1BzOwusvJH3Au61 n6hDjEOVEI7LHoj00BKjUe4qu0PrEEF7RdXav49Rf5dfBs/lSNzEEsaO5X1h8bRnQ0KG 1VR2/TssBGxgK/LV8TnbivOIBSh1NEbdwdLCo=
For instance, this definition for relation is compatible with your script:
Record relation (A:Type) := mk_relation {
  fun_of_rel :> A -> A -> Prop
It defines the required coercion from relation to Funclass.
V
2008/10/23 Mark Dickinson
<dickinsm AT gmail.com>:
> I'm having some trouble understanding how implicit coercion to Funclass
> interacts with definitions.
> Here's a small example to illustrate the problem: the aim is to define
> the type of equivalence relations on a given type A, in such a way that
> if R is an equivalence relation on A and x and y are terms of type A then
> R x y is a valid term.
> (* Begin script *)
> Section Relations.
> Definition relation A : Type := A -> A -> Prop.
> Definition reflexive A (R : relation A) := forall x, R x x.
> Definition symmetric A (R : relation A) := forall x y, R x y -> R y x.
> Definition transitive A (R : relation A) := forall x y z, R y z -> R x
> y -> R x z.
> Record equivalence_relation (A : Type) : Type := {
>  equivalent :> relation A;
>  reflexive_prf : reflexive A equivalent;
>  symmetric_prf : symmetric A equivalent;
>  transitive_prf : transitive A equivalent
> Variable A : Type.
> Variable R : equivalence_relation A.
> Variables x y : A.
> Check R x y.
> End Relations.
> (* End script *)
> Running this under coq version 8.1, the line "Check R x y." fails,
> giving the error message:
> Toplevel input, characters 22-25
> Error: Illegal application (Non-functional construction):
> The expression "R" of type "equivalence_relation A"
> cannot be applied to the term
>  "x" : "A"
> However, if I replace the line "equivalent :> relation A;" by
> "equivalent :> A -> A -> Prop;" then all is well.
> The problem seems to be that the definition of equivalence_relation
> provides an implicit coercion from equivalence_relation to relation,
> but there's no coercion path from relation to Funclass.
> How do I declare the coercion from relation to Funclass so that
> "Check R x y." typechecks?  As a newcomer to Coq, I'm sure
> I'm missing something obvious; any pointers would be appreciated.
> Mark Dickinson
> Bug reports: http://logical.futurs.inria.fr/coq-bugs
> Archives: http://pauillac.inria.fr/pipermail/coq-club
>          http://pauillac.inria.fr/bin/wilma/coq-club
> Info: http://pauillac.inria.fr/mailman/listinfo/coq-club
