coq-club - [Coq-Club] Finite Map - Unable to prove a simple lemma
chronological Thread
  • To: <coq-club AT pauillac.inria.fr>
  • Cc: "Sunil Kothari" <skothari AT uwyo.edu>
  • Subject: [Coq-Club] Finite Map - Unable to prove a simple lemma
  • Date: Tue, 28 Oct 2008 17:29:56 -0600
Hello Coq Users,
   I am programming against the finite map interface based on my earlier posting to this list http://pauillac.inria.fr/pipermail/coq-club/2008/003945.html. I am trying to prove a very simple lemma but somehow I feel the interface (FMapInterface) is missing something. The lemma I am trying to prove is:
 forall s:M.t type, forall n:nat,
not (M.In n s) <->  M.find n s = None.
I was able to prove the lemma  from right to left (please see the below Coq script).
 M.find n s = None -> not (M.In n s)
But I am unable to prove  the other direction i.e.:
not (M.In n s) -> M.find n s = None.
How can I prove it ?  Looking at the proof script you can see I couldn't make much progress. My incomplete  script (and all other needed code) is given below.
Is it because the axiom set (as given FMapInterface) is incomplete ?
Please help.
Sunil
Require Import FMapInterface.
Require Import OrderedTypeEx.
Inductive type:Set :=
    TyVar : nat -> type
  | Arrow : type -> type -> type .
Module Nat_as_MyOT <: UsualOrderedType := Nat_as_OT.
Module MyStuff (M:FMapInterface.S with Module E := Nat_as_MyOT).
(* the type of maps *)
Lemma none_and_find : forall s:M.t type, forall n:nat,
M.find n s = None -> not (M.In n s).
Proof.
intros.
unfold not.
intros.
unfold M.In in H0.
elim H0; intros.
apply M.find_1 in H1.
rewrite H in H1.
inversion H1.
Qed.
Lemma find_and_none: forall s:M.t type, forall n:nat,
Proof.
intros.
unfold M.In in H.
