- To: "Nadeem Abdul Hamid" <nadeem AT acm.org>
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] Mutually inductive types referring to each other
- Date: Thu, 30 Oct 2008 10:59:02 +0100 (CET)
- Importance: Normal
Did you expected something like this:
Inductive sortedlist : nat -> Set :=
| snil : forall n, sortedlist n
| scons : forall (n n':nat) (l:sortedlist n'), n <= n' -> sortedlist n.
I am not sure why it didn't worked, so i won't try to explain it...
Btw, you also ill-typed the rest of your term:
leq_all' -> leq_all
leq_all n nil -> leq_all n snil
leq_all n (cons n' l') -> leq_all n (scons n' l')
> I was trying to reproduce an example similar to one from the Agda
> documentation, using dependent types to define the type of a sorted
> list of numbers:
> Inductive sortedlist : Set :=
> | snil : sortedlist
> | scons : forall (n:nat) (l:sortedlist), leq_all' n l -> sortedlist
> with leq_all : nat -> sortedlist -> Prop :=
> | srt_nil : forall n, leq_all n nil
> | srt_cons : forall n n' l', n <= n' -> leq_all n l' -> leq_all n
> (cons n' l')
> but it gives an error on "sortedlist" in the type of leq_all:
> "Error: The reference sortedlist was not found in the current
> environment."
> Apparently, the names of the types being defined cannot be used in the
> types of other mutually referential definitions? Is there any way to
> do this?
> --- nadeem
> Bug reports: http://logical.futurs.inria.fr/coq-bugs
> Archives: http://pauillac.inria.fr/pipermail/coq-club
> http://pauillac.inria.fr/bin/wilma/coq-club
> Info: http://pauillac.inria.fr/mailman/listinfo/coq-club
Cédric AUGER
Univ Paris-Sud, Laboratoire LRI, UMR 8623, F-91405, Orsay
- [Coq-Club] Mutually inductive types referring to each other, Nadeem Abdul Hamid
- Re: [Coq-Club] Mutually inductive types referring to each other, AUGER Cédric
Nadeem Abdul Hamid
Pierre Casteran
- Re: [Coq-Club] Mutually inductive types referring to each other, Nadeem Abdul Hamid
Nadeem Abdul Hamid
