- From: Pierre Casteran <pierre.casteran AT labri.fr>
- To: Nadeem Abdul Hamid <nadeem AT acm.org>
- Cc: Cedric.Auger AT lri.fr, coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] Mutually inductive types referring to each other
- Date: Fri, 31 Oct 2008 08:56:36 +0100
Nadeem Abdul Hamid a écrit :
No, I'm not trying to define a list indexed by its length. I wasHi,
trying to define a list whose elements are sorted by definition. Every
time a new element, n, is cons'ed to the beginning of an already
sorted list, l, it must be shown to be less than all the elements
already in l (thus, keeping the list sorted in ascending order). The
leq_all is not a function -- it is a property defined inductively
(necessarily mutual with sortedlist) of a number being less than all
numbers in an existing sortedlist: the definition is a bit inverted
from how you would write it as a function, which I think is what you
were thinking...
On Thu, Oct 30, 2008 at 5:59 AM, AUGER Cédric
<Cedric.Auger AT lri.fr>
wrote:
Did you expected something like this:
Inductive sortedlist : nat -> Set :=
| snil : forall n, sortedlist n
| scons : forall (n n':nat) (l:sortedlist n'), n <= n' -> sortedlist n.
Cedric's definition doesn't characterize lists indexed by their length, but by a minorant
of all their elements (in fact their first element).
You can also forget this index :
Inductive SortedList : Set :=
forget_n : forall n, sortedlist n -> SortedList.
Then leq_all is easily defined :
Definition leq_all (p:nat) (l:SortedList) :=
match l with (forget_n n l) => match n with | 0 => True
| q => p <= q end end.
Definition ex1 : SortedList .
refine (forget_n _ (scons 3 _ (scons 5 _ (snil _) _) _));auto with arith.
Defined.
Goal leq_all 2 ex1.
simpl.
auto with arith.
Qed.
Definition bad_ex : SortedList .
refine (forget_n _ (scons 12 _ (scons 5 _ (snil _) _) _));auto with arith.
Abort.
Neither do I ...?
I am not sure why it didn't worked, so i won't try to explain it...
Pierre
Bug reports: http://logical.futurs.inria.fr/coq-bugs
Archives: http://pauillac.inria.fr/pipermail/coq-club
http://pauillac.inria.fr/bin/wilma/coq-club
Info: http://pauillac.inria.fr/mailman/listinfo/coq-club
- [Coq-Club] Mutually inductive types referring to each other, Nadeem Abdul Hamid
- Re: [Coq-Club] Mutually inductive types referring to each other,
AUGER Cédric
Nadeem Abdul Hamid
- Re: [Coq-Club] Mutually inductive types referring to each other, AUGER Cédric
- Re: [Coq-Club] Mutually inductive types referring to each other, Pierre Casteran
- Re: [Coq-Club] Mutually inductive types referring to each other, Nadeem Abdul Hamid
Nadeem Abdul Hamid
AUGER Cédric
