coq-club - [Coq-Club] setoid_rewrite and constant unfolding
chronological Thread
  • To: "coq-club AT pauillac.inria.fr" <coq-club AT pauillac.inria.fr>
  • Subject: [Coq-Club] setoid_rewrite and constant unfolding
  • Date: Sun, 9 Nov 2008 13:20:20 +0000
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=message-id:date:from:to:subject:mime-version:content-type :content-transfer-encoding:content-disposition; b=x2n/WIFtwDn/c7kCpiJG0Ft0nlzvuII1ZRo77RJ/no+szon4SjrLFXqs9H4z9u+Mu5 rN+e9kXMYsYE/Btk6t5IkMC08KI5muQgDbskG932Eb/1fq1fI47keZfZkzPBwajFAlBc X36mVpupth23ZOOAsBVXNBLK5F2PEvUVYTlsY=
Section 23.12 of the reference manual for Coq v8.2, 'Constant
unfolding', seems to say that setoid_rewrite and related tactics
should automatically unfold definitions declared using "Typeclasses
unfold ...".
I'm having some trouble making this work, and am wondering what I'm
doing wrong.  Here's a summary, with the boring bits omitted (the full
code is included at the end of this message).  In the following, 'set'
is a type of setoids, '==' is setoid equality, and 'A >-> B' is the
setoid of '=='-respecting maps from A to B.  After doing:
  Definition binary_operation A : set := A >-> A >-> A.
  Definition associative (A : set) (op : binary_operation A) : Prop := ...
  Definition commutative (A : set) (op : binary_operation A) : Prop := ...
  Typeclasses unfold binary_operation associative commutative.
I declare a type of commutative semigroups with:
  Record ab_semigrp : Type := {
    carrier :> set;
    addition : binary_operation carrier;
    assoc : associative addition;
    comm : commutative addition
  Notation "x + y" := (addition _ x y).
Now I attempt to prove the following:
  Lemma add_rotate : forall A : ab_semigrp, forall x y z : A,
    x + y + z == y + z + x.
  Proof.
    intros.
    setoid_rewrite <- assoc at 1.
    setoid_rewrite comm at 1.
    reflexivity.
  Qed.
But the proof stops at the first 'setoid_rewrite', with the error message:
  Toplevel input, characters 16-44:
  Error: The term does not end with an applied homogeneous relation.
So it looks as though setoid_rewrite can't or won't unfold
'associative'.  If I manually unfold 'associative' in the declaration
of assoc:
  assoc : forall a b c : carrier,
    addition a (addition b c) == addition (addition a b) c;
(and similarly for comm) then the proof works as intended.  I can also
make it work by supplying enough arguments to assoc to force the
unfolding;  for example,
  setoid_rewrite <- (assoc A x) at 1.
  setoid_rewrite (comm A x) at 1.
But if I'm reading section 23.12 right, then neither of these tricks
should be necessary.  What am I missing here?  Is there a good reason
why setoid_rewrite doesn't automatically unfold 'associative'?
I'm using a fairly recent (Nov 1.) build of the v8.2 svn branch.
Here's the complete code.
Set Implicit Arguments.
Require Import Setoid.
(* sets are represented by setoids *)
Record set : Type := {
  element :> Type;
  equal : relation element;
  equiv_prf : equivalence element equal
Notation "x == y" := (equal _ x y) (at level 70, no associativity).
(* Maps A B is the set of functions from a set A to a set B *)
Record function (A B : set) : Type := {
  felement :> A -> B;
  equal_prf : forall x y : A, x == y -> felement x == felement y
Definition fequal (A B : set) (f g : function A B) :=
  forall x, felement f x == felement g x.
Lemma fequal_equiv : forall A B : set, equivalence (function A B) (@fequal A
B).
Proof.
  intros A B. unfold fequal.
  generalize (equiv_prf B); split; elim H; eauto with sets.
Qed.
Definition Maps (A B : set) := Build_set (fequal_equiv A B).
Notation "A >-> B" := (Maps A B) (at level 95, right associativity).
(* register equal and fequal as relations, felement as morphism *)
Add Parametric Relation (A : set) : (element A) (equal A)
  reflexivity proved by (equiv_refl _ _ (equiv_prf A))
  symmetry proved by (equiv_sym _ _ (equiv_prf A))
  transitivity proved by (equiv_trans _ _ (equiv_prf A))
as element_equal_equivalence.
Add Parametric Relation (A B : set) : (function A B) (@fequal A B)
  reflexivity proved by (equiv_refl _ _ (equiv_prf (Maps A B)))
  symmetry proved by (equiv_sym _ _ (equiv_prf (Maps A B)))
  transitivity proved by (equiv_trans _ _ (equiv_prf (Maps A B)))
as function_fequal_equivalence.
Add Parametric Morphism A B : (@felement A B)
  with signature (@fequal A B ==> equal A ==> equal B) as felement_morphism.
Proof.
  unfold fequal. intros f g H1 x y H2.
  generalize (equal_prf g x y H2) (equiv_trans _ _ (equiv_prf B)).
  eauto with sets.
Qed.
  forall a b c : A, op a (op b c) == op (op a b) c.
  forall a b : A, op a b == op b a.
  carrier :> set;
Proof.
  intros.
  reflexivity.
Qed.
