coq-club - Re: [Coq-Club] setoid_rewrite and constant unfolding
chronological Thread
  • To: Mark Dickinson <dickinsm AT gmail.com>
  • Cc: Coq Club <coq-club AT pauillac.inria.fr>
  • Subject: Re: [Coq-Club] setoid_rewrite and constant unfolding
  • Date: Sun, 9 Nov 2008 18:30:16 +0100
Hi Mark,
Le 9 nov. 08 à 14:20, Mark Dickinson a écrit :
Section 23.12 of the reference manual for Coq v8.2, 'Constant
unfolding', seems to say that setoid_rewrite and related tactics
should automatically unfold definitions declared using "Typeclasses
unfold ...".
</snip>
But the proof stops at the first 'setoid_rewrite', with the error message:
 Toplevel input, characters 16-44:
 Error: The term does not end with an applied homogeneous relation.
So it looks as though setoid_rewrite can't or won't unfold
'associative'.  If I manually unfold 'associative' in the declaration
of assoc:
 assoc : forall a b c : carrier,
   addition a (addition b c) == addition (addition a b) c;
(and similarly for comm) then the proof works as intended.  I can also
make it work by supplying enough arguments to assoc to force the
unfolding;  for example,
 setoid_rewrite <- (assoc A x) at 1.
 setoid_rewrite (comm A x) at 1.
But if I'm reading section 23.12 right, then neither of these tricks
should be necessary.  What am I missing here?  Is there a good reason
why setoid_rewrite doesn't automatically unfold 'associative'?
To quote 18.5.4: "It is useful when some constants prevent some
unifications and make resolution fail." This is meant for the typeclass
resolution process. For [setoid_rewrite], it simply means that if you
declared say [map] as a morphism and you use a definition [fn] which really
hides a call to [map] in your goal, then you don't have to redeclare [fn]
itself as a morphism. As all constants are transparent by default, you don't
have anything to do to benefit from that. But it has little to do with reduction
in the type of the lemma.
On the other hand, [setoid_rewrite] could indeed try a little harder at
finding an applied homogeneous relation under definitions, like [rewrite]
does when it tries to find a Leibniz equality. The [setoid_rewrite] tactic
simply didn't try to reduce the type of the lemma at all if it failed, whereas
[rewrite] did as much beta-delta-iota as needed to find the arity of the type
and search for a relation there. I will fix this in the trunk and 8.2 branches.
Your initial proof script will then go through.
Cheers,
-- Matthieu
