- To: "AUGER C�dric" <Cedric.Auger AT lri.fr>
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] Fwd: Forward reference
- Date: Wed, 12 Nov 2008 11:56:22 -0500
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=message-id:date:from:to:subject:cc:in-reply-to:mime-version :content-type:references; b=mCaeVkg0Rc8POU9mv5Kkj4W2twimPY5pGVhF8zAQka3v6O4TS1ZqwXTvOUyxOYe8bI 5GfgGraIxZ5mQXscFT4cNM7Q1kN9phbEHqNE01Wk16arg7YMjSDzXS7Q66TT3ntcHjxy cHW4RUIyMWMwocVDIXrw4hfaLwbXh6ae+9ZjY=
Hi Cedric,
Thanks for your reply. I think you did understand me quite right. However, I am still trying to digest what you have suggested. I will write back as soon as I figure out how your suggestion really works out for me.
I have an immediate question though, which is, if I want to extend this concept to more than two records e.g. A, B, C, D .... etc. wouldn't it get too cluttered and clumsy. Is there a cleaner way to extend the concept you presented?
In case the above is not clear, let me give an example in C code:
struct
a0;struct
a1;struct
a2;struct
b {struct a0 *a00;
struct a1 *a10;
struct a2 *a20;
struct
a0 {int *i;
struct b0 *b00;
struct
a1 {long *j;
struct b0 *b00;
struct
a2 {double *x;
struct b0 *b00;
Hope that makes it clearer.
Thanks again.
On Wed, Nov 12, 2008 at 5:24 AM, AUGER Cédric <Cedric.Auger AT lri.fr> wrote:
Satrajit Roy a écrit :
> Hi guys,I am not sure to understand your question, do you want a mutually
> With reference to the following example, is there a way to forward
> reference Record y and use it in a function defined in Record x. For
> example, as an argument to createX or x''.
> Thanks again.
recursive definition of Record?
It is sadly not yet possible for inductive, and for co-inductive
(http://coq.inria.fr/V8.2beta/CHANGES),
I don't know, but (exepted for extraction purpouses) you can "emulate"
Records as they just are
syntactical sugar.
For example,
> CoInductive A : Set :=
> | cons : A -> B -> A
> with B : Set :=
> | cons2 : A -> B -> B
> Notation "'{' 'A_field' '=' x ';' 'B_field' '=' y '}'" := (cons x y).
> Notation "'{' 'A_field2' '=' x ';' 'B_field2' '=' y '}'" := (cons2 x y).
> Definition A_field A := match A with cons x _ => x end.
> Definition B_field A := match A with cons _ x => x end.
> Definition A_field2 B := match B with cons2 x _ => x end.
> Definition B_field2 B := match B with cons2 _ x => x end.
> Notation "A '.(A_field)'" := (A_field A) (at level 100).
> Notation "A '.(B_field)'" := (B_field A) (at level 100).
> Notation "B '.(A_field2)'" := (A_field2 B) (at level 100).
> Notation "B '.(B_field2)'" := (B_field2 B) (at level 100).
stands for:
Record A : Set :=
cons {A_field : A; B_field : B}
with B : Set :=
cons2 {A_field2 : A; B_field2 : B}.
(you even have better syntax as you can write {A_field = a; B_field = b}
instead of cons a b)
But send a more precise mail if I misunderstood you.
> <mailto:satrajit.roy AT gmail.com>>
> Date: Tue, Nov 11, 2008 at 11:01 AM
> Subject: Re: Lists & Strings> To: coq-club AT pauillac.inria.fr <mailto:coq-club AT pauillac.inria.fr>
> Hi guys,
> How do I resolve the following:
> Require Export List.
> Require Export String.
> Module X.
> Record x: Set := createX {
> x': string;
> x'' : bool
> Record y: Set := createY {
> y': string;
> y'': list x;
> y''': bool :=
> match (length y') return bool with
> | 0 => false
> | _ => true
> end;
> y'''' : bool :=
> match (length y'') return bool with
> | 0 => false
> | _ => true
> end
> End X.
> which results in:
> Error:
> In environment
> y' : string
> y'' : list x
> y''' := (match length y'' with
> | 0 => false
> | S _ => true
> end:bool) : bool
> The term "y''" has type "list x" while it is expected to have type
> "string"
> Thanks , as always, for your time and effort.
- [Coq-Club] Fwd: Forward reference, Satrajit Roy
- Re: [Coq-Club] Fwd: Forward reference,
AUGER Cédric
- Re: [Coq-Club] Fwd: Forward reference, Satrajit Roy
- Re: [Coq-Club] Fwd: Forward reference, AUGER Cédric
AUGER Cédric
