- To: Satrajit Roy <satrajit.roy AT gmail.com>
- Cc: AUGER C�dric <Cedric.Auger AT lri.fr>, coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] Fwd: Forward reference
- Date: Wed, 12 Nov 2008 18:18:44 +0100
As far as I know, there is currently no other way (if not, I am REALLY
interested to know it).
Hopefully,
1. No notation is mandatory, that is
CoInductive A : Set :=
| cons : A -> B -> A
with B : Set :=
| cons2 : A -> B -> B
is sufficient
2. The mess is in proportions with the number of records+fields
In your exemple, there is no mutual recursion, so sort declarations and
use Records
I warn you, using coinductive can be tricky, if you can, use inductives.
Satrajit Roy a écrit :
> Hi Cedric,
> Thanks for your reply. I think you did understand me quite right.
> However, I am still trying to digest what you have suggested. I will
> write back as soon as I figure out how your suggestion really works
> out for me.
> I have an immediate question though, which is, if I want to extend
> this concept to more than two records e.g. A, B, C, D .... etc.
> wouldn't it get too cluttered and clumsy. Is there a cleaner way to
> extend the concept you presented?
> In case the above is not clear, let me give an example in C code:
> struct
> a0;
> struct
> a1;
> struct
> a2;
> struct
> b {
> struct a0 *a00;
> struct a1 *a10;
> struct a2 *a20;
> struct
> a0 {
> int *i;
> struct b0 *b00;
> struct
> a1 {
> long *j;
> struct b0 *b00;
> struct
> a2 {
> double *x;
> struct b0 *b00;
> Hope that makes it clearer.
> Thanks again.
> On Wed, Nov 12, 2008 at 5:24 AM, AUGER Cédric
>Â <Cedric.Auger AT lri.fr
>Â <mailto:Cedric.Auger AT lri.fr>>
> > Hi guys,
> > With reference to the following example, is there a way to forward
> > reference Record y and use it in a function defined in Record x. For
> > example, as an argument to createX or x''.
> > Thanks again.
> I am not sure to understand your question, do you want a mutually
> recursive definition of Record?
> It is sadly not yet possible for inductive, and for co-inductive
> (http://coq.inria.fr/V8.2beta/CHANGES),
> I don't know, but (exepted for extraction purpouses) you can "emulate"
> Records as they just are
> syntactical sugar.
> For example,
> > | cons : A -> B -> A
> > with B : Set :=
> > | cons2 : A -> B -> B
> > Notation "'{' 'A_field' '=' x ';' 'B_field' '=' y '}'" := (cons
> x y).
> > Notation "'{' 'A_field2' '=' x ';' 'B_field2' '=' y '}'" :=
> (cons2 x y).
> > Definition A_field A := match A with cons x _ => x end.
> > Definition B_field A := match A with cons _ x => x end.
> > Definition A_field2 B := match B with cons2 x _ => x end.
> > Definition B_field2 B := match B with cons2 _ x => x end.
> > Notation "A '.(A_field)'" := (A_field A) (at level 100).
> > Notation "A '.(B_field)'" := (B_field A) (at level 100).
> > Notation "B '.(A_field2)'" := (A_field2 B) (at level 100).
> > Notation "B '.(B_field2)'" := (B_field2 B) (at level 100).
> stands for:
> Record A : Set :=
> cons {A_field : A; B_field : B}
> with B : Set :=
> cons2 {A_field2 : A; B_field2 : B}.
> (you even have better syntax as you can write {A_field = a;
> B_field = b}
> instead of cons a b)
> But send a more precise mail if I misunderstood you.
> > ---------- Forwarded message ----------
> > From: *Satrajit Roy*
>Â <satrajit.roy AT gmail.com
>Â <mailto:satrajit.roy AT gmail.com>
>Â <mailto:satrajit.roy AT gmail.com>>>
> > Date: Tue, Nov 11, 2008 at 11:01 AM
> > Subject: Re: Lists & Strings
> > To:
>Â coq-club AT pauillac.inria.fr
>Â <mailto:coq-club AT pauillac.inria.fr>
>Â <mailto:coq-club AT pauillac.inria.fr>>
> > Hi guys,
> > How do I resolve the following:
> > Require Export List.
> > Require Export String.
> > Module X.
> > Record x: Set := createX {
> > x': string;
> > x'' : bool
> > Record y: Set := createY {
> > y': string;
> > y'': list x;
> > y''': bool :=
> > match (length y') return bool with
> > | 0 => false
> > | _ => true
> > end;
> > y'''' : bool :=
> > match (length y'') return bool with
> > | 0 => false
> > | _ => true
> > end
> > End X.
> > which results in:
> > Error:
> > In environment
> > y' : string
> > y'' : list x
> > y''' := (match length y'' with
> > | 0 => false
> > | S _ => true
> > end:bool) : bool
> > The term "y''" has type "list x" while it is expected to have type
> > "string"
> > Thanks , as always, for your time and effort.
- [Coq-Club] Fwd: Forward reference, Satrajit Roy
- Re: [Coq-Club] Fwd: Forward reference,
AUGER Cédric
Satrajit Roy
- Re: [Coq-Club] Fwd: Forward reference, AUGER Cédric
Satrajit Roy
AUGER Cédric
