coq-club - Re: [Coq-Club] Axioms of parametricity?
chronological Thread
  • To: "JAEGER, Eric (SGDN)" <eric.jaeger AT sgdn.gouv.fr>
  • Cc: Taral <taralx AT gmail.com>, Andr� Hirschowitz <ah AT unice.fr>, coq-club AT pauillac.inria.fr
  • Subject: Re: [Coq-Club] Axioms of parametricity?
  • Date: Wed, 19 Nov 2008 09:32:30 +0100
JAEGER, Eric (SGDN) wrote:
Variable var : Type.
Inductive test : Type :=
| A : var -> test
| B : test.
Goal forall T (f : T -> test) x y v, f x = A v -> exists v', f y = A v'.
Sorry, but I do not understand either. Nothing prevents f to return B for some y, even once you have exhibited a value x such that f x=A v. In such a case your goal appears false.
By the way, f var x=A v proves that var is not empty only if you assume that T is not (but I agree that if T is empty then your goal is trivially true).
   Regards, Eric
I believe Taral wants to find a generic condition to impose on f that would ensure the goal he has in mind. Somehow like Girard's idea, when studying second-order lambda-calculus, to say that polymorphic functions cannot be arbitrary and that the "meaning" of a polymorphic type is the intersection of all possible meanings for instances the polymorphic parameter, instead of the reunion. Just to explain the previous sentence in an example, there can be only one polymorphic function of type forall A:type, A -> A, and this function is necessarily the identity function (you have to find the intersection of unit -> unit, nat -> nat, Z -> Z, bool -> bool, they all contain the identity function and it is the only function --or behavior-- that can be common to these types), because the behavior cannot depend on the specific structure of specific instances of A. I believe this is what is meant by "parametricity".
Now, representing polymorphism by universal quantification does not provide this property because, as was rightly pointed out by everybody but Taral, you can always instantiate universal quantification in weird ways. However none of these instantiations falls in the "intersection". So the problem could be re-phrased in: what is the condition that can be expressed on "f" that rejects all the weird instances?
Now, even if I believe I understood Taral's question, I still don't see how to answer it. I don't see a way to express (inside Coq) that some function is at the same time in (nat -> nat) and in (Z -> Z). You cannot speak about the function itself (each function basically has a single type and in some sense the types nat -> nat and Z -> Z have an empty intersection), but about its "behavior", which should be some untyped information and can be shared with other functions in other types...
I am not sure this helps,  but I still hope,
Yves
