- To: Coq Club <coq-club AT pauillac.inria.fr>
- Subject: Re: [Coq-Club] Axioms of parametricity?
- Date: Wed, 19 Nov 2008 11:05:07 +0100
Hi everyone,
Le 19 nov. 08 à 09:32, Yves Bertot a écrit :
JAEGER, Eric (SGDN) wrote:
I believe Taral wants to find a generic condition to impose on f that would ensure the goal he has in mind. Somehow like Girard's idea, when studying second-order lambda-calculus, to say that polymorphic functions cannot be arbitrary and that the "meaning" of a polymorphic type is the intersection of all possible meanings for instances the polymorphic parameter, instead of the reunion. Just to explain the previous sentence in an example, there can be only one polymorphic function of type forall A:type, A -> A, and this function is necessarily the identity function (you have to find the intersection of unit -> unit, nat -> nat, Z -> Z, bool -> bool, they all contain the identity function and it is the only function --or behavior-- that can be common to these types), because the behavior cannot depend on the specific structure of specific instances of A. I believe this is what is meant by "parametricity".Variable var : Type.
Inductive test : Type :=
| A : var -> test
| B : test.
Goal forall T (f : T -> test) x y v, f x = A v -> exists v', f y = A v'.
Sorry, but I do not understand either. Nothing prevents f to return B for some y, even once you have exhibited a value x such that f x=A v. In such a case your goal appears false.
By the way, f var x=A v proves that var is not empty only if you assume that T is not (but I agree that if T is empty then your goal is trivially true).
Regards, Eric
Now, representing polymorphism by universal quantification does not provide this property because, as was rightly pointed out by everybody but Taral, you can always instantiate universal quantification in weird ways. However none of these instantiations falls in the "intersection". So the problem could be re-phrased in: what is the condition that can be expressed on "f" that rejects all the weird instances?
Now, even if I believe I understood Taral's question, I still don't see how to answer it. I don't see a way to express (inside Coq) that some function is at the same time in (nat -> nat) and in (Z -> Z). You cannot speak about the function itself (each function basically has a single type and in some sense the types nat -> nat and Z -> Z have an empty intersection), but about its "behavior", which should be some untyped information and can be shared with other functions in other types...
I am not sure this helps, but I still hope,
It can be characterized in a way by saying that the function preserves any relation
between two arguments, e.g. for the polymorphic identity:
[forall (A : Type) (R : relation A), forall x y, R x y -> R (id x) (id y)]
Equivalently, you could say (using some new definitions found in Classes/Morphisms)
[forall A (R : relation A), Morphism (R ==> R) (@id A)] which unfolds to the same
statement.
In the particular example with [f : forall T, T -> Test], you would need the condition
[forall T (RT : relation T), Morphism (RT ==> eq) f].
By instantiating this with the trivial relation (fun x y : T, True), you get that
[forall x y, f T x = f T y].
I believe this is not provable for any variable [f] of type [forall T, T -> Test] but
by a parametricity theorem any instance for some concrete [f] should be derivable.
This characterization as relational parametricity goes back to Wadler's "Theorems for free!"
and possibly Reynolds and Girard as well. I don't know if it's been studied in the
particular setting of the Inductive Constructions though, but there ought to be
a similar meta-theorem. I hope someone more knowledgable on the metatheory can clear
it out!
Hope this helps,
-- Matthieu
- [Coq-Club] Axioms of parametricity?, Taral
- Re: [Coq-Club] Axioms of parametricity?,
André Hirschowitz
Taral
- Re: [Coq-Club] Axioms of parametricity?, Matthew Brecknell
JAEGER, Eric (SGDN)
Yves Bertot
- Re: [Coq-Club] Axioms of parametricity?, Matthieu Sozeau
Yves Bertot
Taral
André Hirschowitz
