coq-club - Re: [Coq-Club] induction & dependent destruction question
chronological Thread
  • To: Thomas Braibant <thomas.braibant AT gmail.com>
  • Cc: coq-club AT pauillac.inria.fr
  • Subject: Re: [Coq-Club] induction & dependent destruction question
  • Date: Sat, 22 Nov 2008 14:33:02 +0100
Le 21 nov. 08 à 10:09, Thomas Braibant a écrit :
Hi,
Hi,
Maybe this is a very naive question, but I have trouble using dependent
destruction under coq 8.2 beta4.
It's alright, it's a recent addition :)
In the following minimal exemple, I want to prove inversion lemmas on
(dependent) inductive objects. I am able to use the dependent destruction
tactic if our inductive definition is defined in Type, but not in Prop.
However, converting by hand the proof term generated for the Type lemma, we are
able to construct a valid proof term for the Prop lemma. Is there a general way
to prove this kind of lemmas in Prop (using tactics), rather than hacking a
proof term ?
Yes, there is. The problem is that no dependent elimination principle is generated
for eliminating [t_typ] to [Prop], so the [destruct] behind [dependent destruction]
fails. Only [case] is able to handle this case by generating an ad-hoc elimination.
Sadly, the tactic [dependent destruction] is defined in 8.2beta4 as:
<< Tactic Notation "dependent" "destruction" ident(H) :=
  do_depind' ltac:(fun hyp => destruct hyp) H.>>
One way to fix it is to use [case] instead of [destruct] here, but that means
generating ad-hoc principles on the fly which could be costly. Once you generate
the proper induction scheme using:
<<Scheme t_prop_dep := Induction for t_prop Sort Prop.>>, you can add
[using t_prop_dep] clauses to your [dependent desctruction/induction] calls
to get the expected behavior.
You can still improve on that using some existing infrastructure in
[Program.Equality] that I didn't use in [dependent destruction] tactics
that allows to register the prefered dependent elimination principle
associated to a datatype to avoid repeating it everywhere.
There is a typeclass
Class DependentEliminationPackage (A : Type) :=
  elim_type : Type ; elim : elim_type.
and two tactics [elim_case] and [elim_ind] that check the type of the eliminated
object, try to retrieve their eliminator and finally apply [destruct using] or
[induction using]. Now you can redefine [dependent destruction] using this tactic,
even falling back to [case] in case no eliminator is declared. As a side note,
[case] doesn't cleanup the goal at all after application, so you might have some
manual simplifications to do. Anyway, by declaring the dependent elimination
principle for [t_prop] you get what you want:
 Require Import Coq.Program.Equality.
      do_depind' ltac:(fun hyp => elim_case hyp || case hyp) H.
    Variable Z : Type.
    Inductive Obj : Type :=
    | Eq : Obj
    | Neq : Obj.
    Inductive t_prop : Z -> Z -> Obj -> Prop :=
    | t_prop_eq : forall A, t_prop A A Eq
    | t_prop_neq : forall A B, t_prop A B Neq
Instance t_depelim x y o : DependentEliminationPackage (t_prop x y o) :=
      elim := t_prop_dep.
Lemma lemma_prop : forall A B (u : t_prop A B Eq), (A=B)/\ (JMeq u (t_prop_eq A)).
    Proof.
      intros A B u ; dependent destruction u; constructor; reflexivity.
    Qed.
Moreover, the last part of the code deals with an exemple where I can't use
induction, because it leads to an ill-typed term. Could someone explain this
situation ? It seems that this could be related to the inductives Scheme
generated by default when using "Inductive" keyword, sometimes the Minimality
Scheme, and sometimes the "Normal" one.
In this case, it's even more important to use the [elim_ind] tactic, as there's
no equivalent to [case] which would build an ad-hoc induction principle on the fly.
The fact that [induction] fails is just a regular occurence of the problem with the
elimination of dependent objects, as [u] has type [t_prop A B Neq] where [Neq] is
some constructor and [u] appears in the goal. One cannot generalize the type of [u] to
some [t_prop A' B' O] for fresh variable [A', B', O], which is needed to apply the
[induction] tactic.
Again, you can rebind the [dependent induction] tactic notation and do:
  Tactic Notation "dependent" "induction" ident(H) :=
    do_depind' ltac:(fun hyp => elim_ind hyp || induction hyp) H.
  (* Another exemple : even induction goes wrong *)
  Parameter X : Z -> Z -> Type.
  Parameter zero : forall A B,   X A B.
  Parameter one  : forall A,     X A A.
  Set Implicit Arguments.
  Inductive eval :  forall A B u, t_prop A B u -> X A B -> Prop :=
  | eval_eq : forall A, eval (t_prop_eq A) (one A : X A A)
  | eval_neq : forall A B, eval (t_prop_neq A B) (zero A B: X A B)
Lemma ex_ind_prop : forall A B (u : t_prop A B Neq), eval u (zero A B) .
    intros A B u. dependent induction u. constructor.
  Qed.>>
Hope this helps,
-- Matthieu
