- From: "Thomas Braibant" <thomas.braibant AT gmail.com>
- To: coq-club AT pauillac.inria.fr
- Subject: [Coq-Club] induction & dependent destruction question
- Date: Fri, 21 Nov 2008 10:09:28 +0100
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=message-id:date:from:to:subject:in-reply-to:mime-version :content-type:references; b=r442uBCKqiN+RDTcANEOOmr0UZKnAncx8yvkPFCHGU2Rh7L6l679qaCP/FhPAaxgTV yIrwwqquC1jH6GAO7JOfi4T16GgzujY4H6IAdFlsxUyU2YeUNyYCzADlXR+SirKdLCH7 CeT+9mENOn4ELC2CAXY4O796ioiBjnxjH32PM=
Hi,
Maybe this is a very naive question, but I have trouble using dependent
destruction under coq 8.2 beta4.
In the following minimal exemple, I want to prove inversion lemmas on
(dependent) inductive objects. I am able to use the dependent destruction
tactic if our inductive definition is defined in Type, but not in Prop.
However, converting by hand the proof term generated for the Type lemma, we are
able to construct a valid proof term for the Prop lemma. Is there a general way
to prove this kind of lemmas in Prop (using tactics), rather than hacking a
proof term ?
Moreover, the last part of the code deals with an exemple where I can't use
induction, because it leads to an ill-typed term. Could someone explain this
situation ? It seems that this could be related to the inductives Scheme
generated by default when using "Inductive" keyword, sometimes the Minimality
Scheme, and sometimes the "Normal" one.
Thanks a lot.
Thomas
PS : sorry for multiple posts, I have had troubles to send this e-mail to the list
Code begins here :
Require Import Coq.Program.Equality.
(* Type part *)
Variable Z : Type.
Inductive Obj : Type :=
| Eq : Obj
| Neq : Obj.
Inductive t_typ : Z -> Z -> Obj -> Type :=
| t_typ_eq : forall A, t_typ A A Eq
| t_typ_neq : forall A B, t_typ A B Neq
Lemma lemma_typ : forall A B (u : t_typ A B Eq), (A=B)/\ (JMeq u (t_typ_eq
A)).
Proof.
intros A B u; dependent destruction u; constructor; reflexivity.
Qed.
(* Prop part *)
Inductive t_prop : Z -> Z -> Obj -> Prop :=
| t_prop_eq : forall A, t_prop A A Eq
| t_prop_neq : forall A B, t_prop A B Neq
Print lemma_typ.
(* change the printed term to erase the notation for JMeq *)
Lemma lemma_prop : forall A B (u : t_prop A B Eq), (A=B)/\ (JMeq u
(t_prop_eq A)).
Proof.
(* The proof we would like to use :
exact (
fun (A B : Z) (u : t_prop A B Eq) =>
match
u as t in (t_prop z z0 o)
return
(forall u0 : t_prop z z0 Eq,
JMeq t u0 ->
o = Eq ->
z = z0 /\ JMeq u0 (t_prop_eq z))
with
| t_prop_eq A0 =>
fun (u0 : t_prop A0 A0 Eq)
(H : JMeq (t_prop_eq A0) u0)
(_ : Eq = Eq) =>
let H1 := JMeq_eq H in
eq_ind (t_prop_eq A0)
(fun u1 : t_prop A0 A0 Eq =>
A0 = A0 /\ JMeq u1 (t_prop_eq A0))
(conj (refl_equal A0) (JMeq_refl (t_prop_eq A0))) u0 H1
| t_prop_neq A0 B0 =>
fun (u0 : t_prop A0 B0 Eq)
(_ : JMeq (t_prop_neq A0 B0) u0)
(H0 : Neq = Eq) =>
let H1 :=
eq_ind Neq
(fun e : Obj => match e with
| Eq => False
| Neq => True
end) I Eq H0 in
False_ind
(A0 = B0 /\ JMeq u0 (t_prop_eq A0))
H1
end u (JMeq_refl u) (refl_equal Eq)
Qed.
(* Another exemple : even induction goes wrong *)
Parameter X : Z -> Z -> Type.
Parameter zero : forall A B, X A B.
Parameter one : forall A, X A A.
Inductive eval : forall A B u, t_prop A B u -> X A B -> Prop :=
| eval_eq : forall A, eval (t_prop_eq A) (one A : X A A)
| eval_neq : forall A B, eval (t_prop_neq A B) (zero A B: X A B)
Lemma ex_ind_prop : forall A B (u : t_prop A B Neq), eval u (zero A B) .
intros A B u.
induction u.
Abort.
proof term ?
Thanks a lot.
Thomas
Code begins here :
(* Type part *)
Variable Z : Type.
| Eq : Obj
| Neq : Obj.
A)).
Proof.
Qed.
(* Prop part *)
Print lemma_typ.
(t_prop_eq A)).
Proof.
exact (
match
return
JMeq t u0 ->
o = Eq ->
with
| t_prop_eq A0 =>
(_ : Eq = Eq) =>
| t_prop_neq A0 B0 =>
(H0 : Neq = Eq) =>
let H1 :=
eq_ind Neq
| Eq => False
| Neq => True
end) I Eq H0 in
False_ind
H1
Qed.
intros A B u.
induction u.
Abort.
- [Coq-Club] induction & dependent destruction question, Thomas Braibant
- Message not available
Thomas Braibant
- Re: [Coq-Club] induction & dependent destruction question, Matthieu Sozeau
Thomas Braibant
