- From: Benjamin Werner <benjamin.werner AT inria.fr>
- To: Thorsten Altenkirch <txa AT Cs.Nott.AC.UK>
- Cc: Coq Club <coq-club AT pauillac.inria.fr>
- Subject: Re: [Coq-Club] Russell's paradox
- Date: Sat, 29 Nov 2008 21:36:16 +0100
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=cc:message-id:from:to:in-reply-to:content-type :content-transfer-encoding:mime-version:subject:date:references :x-mailer:sender; b=VvJENeMuna20PeuWQaHkO5c4EWDwmVmz8Jm0+YCo3n+MFF+7+W1krp2jKtL4fdh5cG OEM4Pp3quO8rl2WXdLmXwSvFITv3nfG28cyNT4ojWpYglt7614KzXRfo6TJ1iJEfu3/G FEp7Wi+rwi1VaUIwC/5UBrvrlYB4U51KtXZt0=
Hi,
Nice version of Russell's paradox.
Two remarks :
- One does not need K nore dependent inversion for the matter.
Just do "case eq" where eq is your equality proof.
- You can simplify your development by noticing right away
that all trees are "good".
Cheers,
Benjamin
(** Mathematics for Computer Scientists 2 (G52MC2)
Thorsten Altenkirch
L16 (Russell's paradox)
The material in this file contains coq proofs
which can be read and animated with coqide or xemacs+proofgeneral.
Section russell.
Set Implicit Arguments.
Variable set : Set.
Variable name : Set -> set.
Variable El : set -> Set.
Axiom reflect : forall A:Set,A = El (name A).
Inductive Tree : Set :=
span : forall a : set, (El a -> Tree) -> Tree.
Definition elem (t : Tree) (u : Tree) : Prop
:= match u with
| span A us => exists a : El A , t = us a
end.
Definition Bad (t : Tree) : Prop
:= elem t t.
Lemma is_good : forall t, ~Bad t.
induction t; intros [x ex].
unfold not in H; apply (H x).
rewrite <- ex.
exists x; trivial.
Qed.
Definition tree := name Tree.
Definition getTreeAux : forall A : Set, Tree = A -> A -> Tree.
intros A e a; rewrite e; exact a.
Defined.
Definition getAuxTree : forall A : Set, Tree = A -> Tree -> A.
intros A e a; rewrite <- e; exact a.
Defined.
Definition getTree : El tree -> Tree :=
fun e => (getTreeAux (reflect _ ) e).
Definition Russell := (span getTree).
Lemma is_bad : (Bad Russell).
exists (getAuxTree (reflect _) Russell).
unfold getTree.
case (reflect Tree).
trivial.
Qed.
Definition paradox : False := (is_good _ is_bad).
Le 29 nov. 08 à 15:03, Thorsten Altenkirch a écrit :
I suspect I need K (or I am just too stupid). Can anybody conform either? I.e. can I prove this using Coq.Logic.Eqdep or without?
I am just too stupid. But so is Coq. I just need to use dependent inversion.
Actually I realized that I can prove it with the standard eliminator for equality:
eq_elim : forall (A:Set)(x:A)(P:forall y:A, (x=y)->Set)
(m:P x (refl_equal x))
(y:A)(p:x=y),P y p.
This is not automatically derived by Coq (why not?) but it can be proven using dependent inversion. It seems that you always get in trouble if you try to use dependent types in Coq.
I attach my completed Russell derivation.
Cheers,
Thorsten
This message has been checked for viruses but the contents of an attachment
may still contain software viruses, which could damage your computer system:
you are advised to perform your own checks. Email communications with the
University of Nottingham may be monitored as permitted by UK legislation.
<l16-crib.v>
- [Coq-Club] Russell's paradox, Thorsten Altenkirch
- Re: [Coq-Club] Russell's paradox, Adam Chlipala
Thorsten Altenkirch
Robin Green
- Re: [Coq-Club] Russell's paradox, Pierre Letouzey
- Re: [Coq-Club] Russell's paradox, Benjamin Werner
- Re: [Coq-Club] Russell's paradox, Thorsten Altenkirch
Robin Green
