- To: Stefan Holdermans <stefan AT cs.uu.nl>
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] Beginner's question on induction
- Date: Wed, 07 Jan 2009 14:02:48 -0500
Stefan Holdermans wrote:
Finally, I'd like to establish the following theorem:
Theorem T : forall a n, Q a (S n) -> Q a (S (S n)).
I would have guessed that, given the lemma L, the proof of T would amount to a routine induction on a derivation of Q a (S n) for arbitrary a and n. However, brazenly starting with
Proof.
intros a n Hq. induction Hq.
Coq gives me the following hypotheses and subgoal for the case for q_base:
n : nat
m : nat
n0 : nat
H : P m n0
Q (base m) (S n0)
And so I'm stuck! I would have expected some evidence of n0 = S n or perhaps just H : P m (S n) and the goal Q (base m) (S (S n)).
Could someone explain the experienced behaviour? Am I missing something obvious and is there a straightforward workaround?
This is one of the most common problems in getting started with Coq. [induction] only works over predicates applied to arguments that are all variables. In your case, one of the arguments is [S n]. I would prefer that Coq signal an error in this case. Instead, the current [induction] implementation replaces each complex term with a fresh variable, forgetting structural details.
My usual tack is to restate the theorem as a lemma where all the arguments to the predicate to be inducted over really are variables. You usually achieve this by introducing new auxiliary variables and relating these to the predicate arguments using new equality hypotheses.
- [Coq-Club] Beginner's question on induction, Stefan Holdermans
- Re: [Coq-Club] Beginner's question on induction, Adam Chlipala
Stefan Holdermans
Stefan Holdermans
- Re: [Coq-Club] Beginner's question on induction, Taral
