coq-club - Re: [Coq-Club] Beginner's question on induction
chronological Thread
  • To: Stefan Holdermans <stefan AT cs.uu.nl>
  • Cc: coq-club AT pauillac.inria.fr
  • Subject: Re: [Coq-Club] Beginner's question on induction
  • Date: Wed, 07 Jan 2009 15:29:50 -0500
Stefan Holdermans wrote:
This is one of the most common problems in getting started with Coq. [induction] only works over predicates applied to arguments that are all variables. In your case, one of the arguments is [S n]. I would prefer that Coq signal an error in this case. Instead, the current [induction] implementation replaces each complex term with a fresh variable, forgetting structural details.
That is indeed a severe restriction.
It's helpful to consider the restriction in light of how [induction] is implemented with proof terms. Since [induction] looks up induction principles that were generated when types were defined, the relevant details are actually in that principle generation. There, dependent [match] terms are employed, and the limitation on [induction] comes from the limitation of dependent [match]es that all arguments in [in] clauses must be variables. This restriction is hard to relax in a non-heuristic way, because of the undecidability of higher-order unification.
(I've intentionally kept this explanation terse, both because some readers probably don't care about the details and because it is more instructive to poke around the formal definition of CIC based on these prompts than to spend time parsing a long explanation.)
