coq-club - RE: [Coq-Club] Occurrence of keyword in conclusion
chronological Thread
  • To: "'Matthieu Sozeau'" <Matthieu.Sozeau AT lri.fr>
  • Cc: <coq-club AT pauillac.inria.fr>
  • Subject: RE: [Coq-Club] Occurrence of keyword in conclusion
  • Date: Thu, 29 Jan 2009 20:01:00 -0800
Hi Matthieu,
Thank you very much for your prompt reply. I have seen that pattern
construction when I was reading the reference manual (under Chapter 9.1
Syntax). However, the reason why I didn't use it is because there is no
worked examples on it.
Thus may I ask you to give me a simple example on how it is done so that?
Thank you in advance.
Best Regards,
Woon Ming
-----Original Message-----
[mailto:Matthieu.Sozeau AT lri.fr]
Sent: Thursday, January 29, 2009 2:55 AM
To: Woon Ming
Cc:
Subject: Re: [Coq-Club] Occurrence of keyword in conclusion
Le 29 janv. 09 à 23:43, Woon Ming a écrit :
> Hi all,
Hi,
> In my Ltac,  I would like to detect the occurrence of a particular
> keyword in the conclusion and apply the appropriate hypothesis.
> ( e.g.
> My conclusion consists of “a * b = keyword * b”.
> And my ltac is something like this:
> Ltac simplify :=
> match goal with
> | [id:(_=?key) |- (_ = key * b)] => rewrite id.
> end.
> In the example given, it is workable only because I specified the
> operator (*). However, in the case where I don’t specify any
> operator (e.g. (_ =key_)), this is completely not workable. Is there
> any way I can perform regex matching in a generalized manner (e.g.
> without specifying the operator)?
Yes, using the [context [ pat ]] pattern construction.
It is documented in the reference manual.
-- Matthieu
