coq-club - Re: [Coq-Club] Occurrence of keyword in conclusion
chronological Thread
  • To: Woon Ming <woon_ming AT comp.nus.edu.sg>
  • Cc: Coq Club <coq-club AT pauillac.inria.fr>
  • Subject: Re: [Coq-Club] Occurrence of keyword in conclusion
  • Date: Thu, 29 Jan 2009 16:22:13 +0100
Le 30 janv. 09 à 05:01, Woon Ming a écrit :
Hi Matthieu,
Hi Woon,
Thank you very much for your prompt reply. I have seen that pattern
construction when I was reading the reference manual (under Chapter 9.1
Syntax). However, the reason why I didn't use it is because there is no
worked examples on it.
There's a little explanation and an example in the 9.2 "Semantics" section.
It is a variant of [match goal with] expression.
Thus may I ask you to give me a simple example on how it is done so that?
On your example, you could probably simply write
[match goal with context [keyword] => ... end]
Hope this helps,
-- Matthieu
