- To: Elie Soubiran <soubiran AT lix.polytechnique.fr>
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] Leveraging the module system
- Date: Sat, 31 Jan 2009 17:04:47 -0500
I must be missing something.
My original example required that SIG be a signature of a functor over SIG2. Your example eliminates this feature. Is what I want to say not expressible in Coq 8.1 and I should move to 8.2? Or is something more interesting going on?
Scott Doerrie
Elie Soubiran wrote:
Hello,
If you are using coq 8.1 you should do as follow:
Module Type SIG.
Parameter t : T.
Parameter foo : t -> Prop.
End SIG.
Module F (X:SIG2) : SIG with Definition t := X.t.
Definition t : T := P.t.
Definition foo : t -> Prop := ...
End F.
Or if you are using 8.2 or trunk you can keep your type SIG but use it
like this:
Module F (X:SIG2) : SIG X.
Elie
On Fri, Jan 30, 2009 at 10:15 PM, M. Scott Doerrie
<mdoerri AT cs.jhu.edu>
wrote:
I have defined a ModuleType functor and a Module functor somewhat as
follows.
For discussion assume SIG2 is a Module Type.
Module Type SIG (P: SIG2).
Parameter foo : P.t -> Prop.
End SIG.
Module Impl (P:SIG2).
Definition foo (P:t) : Prop := (* implementation *).
End Impl
I can't determine how to declare that Impl is of type SIG? Use of <: and :
operators produce syntactic error messages. I'm sure this is a simple
example, but I am confused by what I thought was straightforward to express.
Scott Doerrie
Bug reports: http://logical.futurs.inria.fr/coq-bugs
Archives: http://pauillac.inria.fr/pipermail/coq-club
http://pauillac.inria.fr/bin/wilma/coq-club
Info: http://pauillac.inria.fr/mailman/listinfo/coq-club
- [Coq-Club] Leveraging the module system, M. Scott Doerrie
- Re: [Coq-Club] Leveraging the module system,
Taral
- Re: [Coq-Club] Leveraging the module system, M. Scott Doerrie
Elie Soubiran
Taral
