- From: Thomas Braibant <thomas.braibant AT gmail.com>
- To: coq-club AT pauillac.inria.fr
- Subject: [Coq-Club] Morphisms & setoid_rewrite under binders
- Date: Wed, 4 Feb 2009 11:50:47 +0100
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:date:message-id:subject:from:to:content-type :content-transfer-encoding; b=J0P5wAHlzJTYiBXPvJYiehUgUQEpAYO7WqssezmvV/NpSqZjTLiNJEiBDh2Y2Kh6/E ZAt1gUM9J/SxYrFaxPF1Vxo+MYvsz3sMa/SAMmFvxHsbuowsxFmYoWDYuxuZhdRVy5uy Lg/BpfQc1vrALcQadC7ijUDrNCTlc4TUfDBtw=
Hi,
The behavior of setoid_rewrite under binders is a little bit
confusing. Could someone explain what is wrong in the following
examples ?
Thanks,
Thomas Braibant
------------------------------------ Code begins here
Require Import Setoid.
Module Nat.
Definition t := nat -> Prop.
Definition mor1 (f : t) : Prop := forall n, f n.
Definition mor2 (i : nat) (f : t) : Prop := forall n, i < n -> f n.
Instance mor1_morph :
Morphism (((@eq nat) ==> iff) ==> iff) (mor1).
Admitted.
Instance mor2_morph (i : nat) :
Morphism (((@eq nat) ==> iff) ==> iff) (@mor2 i).
Admitted.
Hypothesis H : forall n m, (n = m <-> m = n *m).
Goal mor1 (fun n => n = n + n) <-> True.
setoid_rewrite H.
Abort. (* Ok *)
Goal mor2 5 (fun n => n = n + n) <-> True.
setoid_rewrite H. (* does not work *)
Abort.
End Nat.
(* This example looks like the first (working) one in module Nat, and
is not working here *)
Module Exemple.
Variable X: Set.
Variable zero: X.
Variable plus: X -> X -> X.
Variable nplus: nat -> X -> X.
Variable equal: X -> X -> Prop.
Variable sum: (nat -> X) -> X.
Infix "==" := equal (at level 50).
Variable Heq: Equivalence equal.
Variable sum_mor: forall f g, (forall i, f i == g i) -> sum f == sum g.
Instance eqeq : Equivalence equal.
apply Heq.
Qed.
Instance mor_morph :
Morphism (((@eq nat) ==> equal) ==> equal) (@sum).
repeat intro. apply sum_mor. intro. apply H. reflexivity.
Qed.
Hypothesis H: forall x, plus zero x == zero.
Goal sum (fun n => plus zero (nplus n zero)) == zero.
Abort.
End Exemple.
- [Coq-Club] Morphisms & setoid_rewrite under binders, Thomas Braibant
- Re: [Coq-Club] Morphisms & setoid_rewrite under binders, Matthieu Sozeau
