- To: Thomas Braibant <thomas.braibant AT gmail.com>
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] Morphisms & setoid_rewrite under binders
- Date: Wed, 4 Feb 2009 18:27:43 +0100
Le 4 févr. 09 à 11:50, Thomas Braibant a écrit :
Hi,
Hi Thomas,
The behavior of setoid_rewrite under binders is a little bit
confusing. Could someone explain what is wrong in the following
examples ?
There are a number of combined factors that make it hard to understand.
First, the first rewrite works not because of the [Morphism] declaration for
mor1_morph but because mor1 unfolds to [forall] and hence unifies with a previously
declared [Morphism] for the [all] constant. You can test by simply removing the
instance declaration (still works) or making the constant opaque using
[Typeclasses Opaque mor1] (doesn't work anymore).
Second, (@eq A ==> R) is not seen as a subrelation of [pointwise_relation A R]
by default (my bad) hence your Morphism declarations are mostly useless. You
can just add the following Instance to make it work again:
Instance pointwise_eq A B (R : relation B) :
subrelation (pointwise_relation A R) (@eq _ ==> R)%signature.
Proof. reduce. subst. apply H. Qed.
Rewriting the instances to use [pointwise_relation] instead will work too.
Your example also triggers an inefficiency in the search that can only be
solved in the library... This is a somewhat experimental feature as you may
have guessed, thanks for the report!
-- Matthieu
- [Coq-Club] Morphisms & setoid_rewrite under binders, Thomas Braibant
- Re: [Coq-Club] Morphisms & setoid_rewrite under binders, Matthieu Sozeau
