coq-club - Re: [Coq-Club] coqdoc problems
chronological Thread
  • From: Jean-Marc Notin <notin AT lix.polytechnique.fr>
  • To: Fr�d�ric Peschanski <Frederic.Peschanski AT lip6.fr>
  • Cc: coq-club AT pauillac.inria.fr
  • Subject: Re: [Coq-Club] coqdoc problems
  • Date: Wed, 04 Feb 2009 15:02:23 +0100
  • Organization: LIX - CNRS
Hello,
I am using coq  8.1pl3 and I have a hard time using coqdoc
for latex (or even html) output.
I have attached a very short example and I wonder if there is
something wrong somewhere (wrt. coqdoc).
When I run:
coqdoc --latex -g test.v
In the generated test.tex file, the second (** special comment
is not interpreted correctly. This is a silly example but I have
the same problem in a few "real" modules I am working on.
Sometimes the output is simply an empty latex or html document.
Strangely enough, other modules are processed correctly and
I do not understand why.
Is there something wrong with my example or do I have to fill a
coq-bug report ? (maybe I should first try 8.2).
The file you provided is a DOS file (ie lines end up with CRLF) and coqdoc seems to have trouble with it. Using 'dos2unix' solves the problem.
Jean-Marc Notin
CNRS - LIX
Attachment: smime.p7s
Description: S/MIME Cryptographic Signature
