- To: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] Re: Simple example.
- Date: Fri, 20 Feb 2009 02:44:20 +0000
- Organization: Swansea University
On Fri, 20 Feb 2009 08:39:06 -0500
Adam Chlipala
<adamc AT hcoop.net>
wrote:
> On the issue of proofs, I think the proof scripts in both your (Adam
> Koprowski's) code and the code of the mysterious "muad" are manual
> enough that I would refuse to accept them in a serious
> development. ;-) I say that every certified function should have a
> single proof script associated with it, and that proof script should
> be a single tactic, with no intermediate periods. That style (which
> I used in my implementation posted earlier) is easy to use when you
> commit to following it, and it has many advantages in brevity of code
> and resilience to changes in specs and implementations.
But any proof can be turned into a tactic, whose definition is simply
the original proof - but that would achieve nothing. What is the formal
definition of what you mean? ;-)
Robin
- [Coq-Club] Re: Simple example., Adam Koprowski
- Re: [Coq-Club] Re: Simple example.,
Adam Chlipala
- Re: [Coq-Club] Re: Simple example., Robin Green
- Re: [Coq-Club] Re: Simple example., Adam Chlipala
Wouter Swierstra
- Re: [Coq-Club] Re: Simple example., Nadeem Abdul Hamid
- Re: [Coq-Club] Simple example., Adam Chlipala
- Re: Re: [Coq-Club] Simple example.,
muad
Adam Chlipala
