- To: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] Re: Simple example.
- Date: Fri, 20 Feb 2009 08:57:43 -0500
Robin Green wrote:
On Fri, 20 Feb 2009 08:39:06 -0500
Adam Chlipala
<adamc AT hcoop.net>
wrote:
On the issue of proofs, I think the proof scripts in both your (Adam Koprowski's) code and the code of the mysterious "muad" are manual enough that I would refuse to accept them in a serious
development. ;-) I say that every certified function should have a
single proof script associated with it, and that proof script should
be a single tactic, with no intermediate periods. That style (which
I used in my implementation posted earlier) is easy to use when you
commit to following it, and it has many advantages in brevity of code
and resilience to changes in specs and implementations.
But any proof can be turned into a tactic, whose definition is simply
the original proof - but that would achieve nothing. What is the formal
definition of what you mean? ;-)
I don't think it's necessary to give a formal definition; folks tend to get the idea. Proof scripts should almost never follow the structure of the proof, since that makes them brittle to necessary structural changes. This rules out solving every goal by [exact], since this would involve giving proof terms that follow proof structure.
- [Coq-Club] Re: Simple example., Adam Koprowski
- Re: [Coq-Club] Re: Simple example.,
Adam Chlipala
Robin Green
- Re: [Coq-Club] Re: Simple example., Adam Chlipala
Wouter Swierstra
- Re: [Coq-Club] Re: Simple example., Nadeem Abdul Hamid
- Re: [Coq-Club] Simple example., Adam Chlipala
- Re: Re: [Coq-Club] Simple example.,
muad
Robin Green
Adam Chlipala
