- To: Adam Chlipala <adamc AT hcoop.net>
- Cc: coq-club <coq-club AT pauillac.inria.fr>
- Subject: Re: [Coq-Club] Dependent rewrite question (probably simple answer! :)
- Date: Fri, 20 Feb 2009 15:03:06 +0000
Hi Adam,
Thanks for taking the time to reply. However, I'm not sure your answer generalizes to the real proof I'm attempting, since you are taking advantage of the fact that I only introduced one constructor for T. Suppose that we change the definition of T to
Inductive T : nat -> Set :=
| MkT : forall (n:nat), T n
| MkT2 : forall (n:nat), T n.
Trying this, I now also get stuck in my a_is_b lemma :-( Surely I should still be able to prove that a = b and that X U a = X (U + 1 - 1) b?
Edsko
- [Coq-Club] Dependent rewrite question (probably simple answer! :), Edsko de Vries
- Re: [Coq-Club] Dependent rewrite question (probably simple answer! :),
Adam Chlipala
- Re: [Coq-Club] Dependent rewrite question (probably simple answer! :), Edsko de Vries
Adam Chlipala
