- To: Adam Koprowski <adam.koprowski AT gmail.com>
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] Re: Simple example
- Date: Sun, 22 Feb 2009 12:42:18 -0500
Adam Koprowski wrote:
Still I completely miss why would Program be any inferior to refine for such examples, [...]
If you want to reason about your (transparent) definitions after you finish writing them, then [refine] is likely to be much more helpful than [Program]. The latter will add all sorts of coercions "behind the scenes." The program you write will in general not be the Gallina term that you end up with, and it's that Gallina term that you'd need to prove things about.
- Re: [Coq-Club] Re: Simple example, Adam Koprowski
- Re: [Coq-Club] Re: Simple example, Adam Chlipala
Robin Green
Adam Chlipala
Luke Palmer
Luke Palmer
Adam Chlipala
Robin Green
