coq-club - Re: [Coq-Club] Re: Simple example
chronological Thread
  • To: Luke Palmer <lrpalmer AT gmail.com>
  • Cc: coq-club AT pauillac.inria.fr
  • Subject: Re: [Coq-Club] Re: Simple example
  • Date: Sun, 22 Feb 2009 15:26:52 -0500
Luke Palmer wrote:
On Sun, Feb 22, 2009 at 11:21 AM, Adam Chlipala <adamc AT hcoop.net <mailto:adamc AT hcoop.net>> wrote:
    Robin Green wrote:
             [With Program] The program you write will in general not
            be the
            Gallina term that you end up with, and it's that Gallina
            term that
            you'd need to prove things about.
        True, but so what? You can still see the term, but there's no
        need to
        put it in the source file.
    Terms with coercions are _much_ harder to reason about than terms
    without.
I don't know why you think that you don't need the coercions if you write it by hand.
Well, I think it because it's true. ;-) Compare the final Gallina terms in my original example program to what you get with Program. I'm having trouble running Adam Koprowski's version, probably since I'm still using 8.1pl3, but I'm guessing there are coercions in the final generated terms. My version definitely ends up with no coercions.
