- To: Nikhil Swamy <nswamy AT microsoft.com>
- Cc: "coq-club AT pauillac.inria.fr" <coq-club AT pauillac.inria.fr>
- Subject: Re: [Coq-Club] Mutual induction over a single inductive type
- Date: Mon, 23 Feb 2009 00:42:27 +0100
Le 23 févr. 09 à 00:32, Nikhil Swamy a écrit :
Hi,
I have a single inductively defined proposition T and
I need to prove a lemma P over T using mutual induction with
another lemma Q over T. What's the easiest way of doing this? Let
me be more specific, with this contrived example:
Hi,
You have to generate the dependent elimination principle for things
in Prop explicitely, only the non-dependent one is generated by default.
You can then use it to prove the (somewhat strenghtened) induction
principle.
Inductive T : nat -> nat -> Prop :=
| T1 : forall i j k,
T i j -> T j k -> T i k
| T2 : forall i j k,
T k j -> T j i -> T i k.
Scheme T_dep := Induction for T Sort Prop.
Lemma T_mut_ind : forall
(P: forall i j, T i j -> Prop)
(Q: forall i j, T i j -> Prop),
(* P cases *)
(forall i j k (t1: T i j) (t2: T j k),
(P i j t1) ->
(P j k t2) ->
(P i k (T1 i j k t1 t2))) ->
(forall i j k (t1: T k j) (t2: T j i),
(Q k j t1) ->
(Q j i t2) ->
(P i k (T2 i j k t1 t2))) ->
(*Q cases *)
(Q i j t1) ->
(Q j k t2) ->
(Q i k (T1 i j k t1 t2))) ->
(P k j t1) ->
(P j i t2) ->
(Q i k (T2 i j k t1 t2))) ->
(forall i j (t:T i j), P i j t /\ Q i j t).
Proof.
intros.
induction t using T_dep ; intuition.
Qed.
-- Matthieu
- [Coq-Club] Mutual induction over a single inductive type, Nikhil Swamy
- Re: [Coq-Club] Mutual induction over a single inductive type, Adam Chlipala
- Re: [Coq-Club] Mutual induction over a single inductive type, Matthieu Sozeau
- RE: [Coq-Club] Mutual induction over a single inductive type,
Nikhil Swamy
- Re: [Coq-Club] Mutual induction over a single inductive type, Hugo Herbelin
Nikhil Swamy
