coq-club - RE: [Coq-Club] Mutual induction over a single inductive type
chronological Thread
  • To: Matthieu Sozeau <Matthieu.Sozeau AT lri.fr>
  • Cc: "coq-club AT pauillac.inria.fr" <coq-club AT pauillac.inria.fr>
  • Subject: RE: [Coq-Club] Mutual induction over a single inductive type
  • Date: Sun, 22 Feb 2009 15:54:33 -0800
  • Accept-language: en-US
  • Acceptlanguage: en-US
This works great! Thanks Matthieu for the prompt response. Adam: I find it
much more convenient to prove my lemma this way rather than proving the
conjunction of P and Q for each constructor. Thanks to you too for the quick
response. -Nik
________________________________________
[Matthieu.Sozeau AT lri.fr]
Sent: Sunday, February 22, 2009 3:42 PM
To: Nikhil Swamy
Cc:
Subject: Re: [Coq-Club] Mutual induction over a single inductive type
Le 23 févr. 09 à 00:32, Nikhil Swamy a écrit :
> Hi,
> I have a single inductively defined proposition T and
> I need to prove a lemma P over T using mutual induction with
> another lemma Q over T. What's the easiest way of doing this? Let
> me be more specific, with this contrived example:
Hi,
   You have to generate the dependent elimination principle for things
in Prop explicitely, only the non-dependent one is generated by default.
You can then use it to prove the (somewhat strenghtened) induction
principle.
Inductive T : nat -> nat -> Prop :=
| T1 : forall i j k,
  T i j -> T j k -> T i k
| T2 : forall i j k,
  T k j -> T j i -> T i k.
Scheme T_dep := Induction for T Sort Prop.
Lemma T_mut_ind : forall
  (P: forall i j, T i j -> Prop)
  (Q: forall i j, T i j -> Prop),
  (* P cases *)
  (forall i j k (t1: T i j) (t2: T j k),
    (P i j t1) ->
    (P j k t2) ->
    (P i k (T1 i j k t1 t2))) ->
  (forall i j k (t1: T k j) (t2: T j i),
    (Q k j t1) ->
    (Q j i t2) ->
    (P i k (T2 i j k t1 t2))) ->
  (*Q cases *)
    (Q i j t1) ->
    (Q j k t2) ->
    (Q i k (T1 i j k t1 t2))) ->
    (P k j t1) ->
    (P j i t2) ->
    (Q i k (T2 i j k t1 t2))) ->
  (forall i j (t:T i j), P i j t /\ Q i j t).
Proof.
   intros.
   induction t using T_dep ; intuition.
Qed.
-- Matthieu
