- To: Hai WAN <wan.whyhigh AT gmail.com>
- Cc: Coq Club <coq-club AT pauillac.inria.fr>
- Subject: Re: [Coq-Club] The dependency graphs of Coq theorems
- Date: Fri, 27 Feb 2009 15:25:19 +0100
Hai WAN wrote:
Dear all,One of the missing basic blocks is a command that makes it possible to generate a list of all theorems that are used in the proof of another theorem. Here is a file that defines such a command. I tested it on CoqV8.1pl3 and the trunk version of today. It should be a trivial matter to extend this command so that it performs the search of dependencies recursively on all theorems on which the first argument depends, but I don't have the time to do it just now. This could also be turned into a plugin for Coq.
Is there any commands can help me to explore the dependencies among theorems
in a Coq proof script?
I've found a paper about this : Dependency Graphs for Interactive Theorem
Provers (2000) and wonder is there any realization of this idea?
Thanks in advance.
To test this file, you should normally have to perform the following steps:
coq_makefile -f Make > Makefile
make
./coqthmdep
An example of usage is the following command: this lists all the objects (except for
constructors of inductive types) that the theorem mult_n_Sm depends on.
SearchDepend mult_n_Sm.
Yves
(*i camlp4deps: "parsing/grammar.cma" i*)
open Names;;
open Libnames;;
open Term;;
open Pp;;
open Printer;;
open Global;;
open Declarations;;
open Constrintern;;
open Environ;;
type data = {ind : KNset.t; con : Cset.t}
let add_identifier (x:identifier)(d:data) =
failwith
("SearchDep does note expect to find plain identifiers :" ^
string_of_id x);;
let add_sort (s:sorts)(d:data) = d;;
let add_constant (cst:constant)(d:data) =
{ind = d.ind; con = Cset.add cst d.con};;
let add_inductive ((k,i):inductive)(d:data) =
{ind = KNset.add k d.ind; con = d.con}
let add_constructor(((k,i),j):constructor)(d:data) =
let collect_long_names (c:constr) (acc:data) =
let rec f c acc =
match kind_of_term c with
Rel _ -> acc
| Var x -> add_identifier x acc
| Meta _ -> assert false
| Evar _ -> assert false
| Sort s -> add_sort s acc
| Cast(c,_,t) -> f c (f t acc)
| Prod(n,t,c) -> f t (f c acc)
| Lambda(n,t,c) -> f t (f c acc)
| LetIn(_,v,t,c) -> f v (f t (f c acc))
| App(c,ca) -> f c (Array.fold_right f ca acc)
| Const cst -> add_constant cst acc
| Ind i -> add_inductive i acc
| Construct cnst -> add_constructor cnst acc
| Case({ci_ind=i},c,t,ca) ->
add_inductive i (f c (f t (Array.fold_right f ca acc)))
| Fix(_,(_,ca,ca')) -> Array.fold_right f ca (Array.fold_right f ca' acc)
| CoFix(_,(_,ca,ca')) -> Array.fold_right f ca (Array.fold_right f ca' acc)
in f c acc;;
let display_global_references (d:data) =
msgnl [< str"[" ++
(Cset.fold (fun r s -> [<pr_global (ConstRef r) ++ spc() ++s >])
d.con
(KNset.fold (fun r s ->
[<pr_global (IndRef(r,0)) ++ spc() ++ s >])
d.ind (str "]"))) >];;
let empty_data = {ind = KNset.empty; con = Cset.empty}
let display_inductive (i:inductive) =
let _, indbody = lookup_inductive i in
let {mind_user_lc=ca} = indbody in
let deps = Array.fold_right collect_long_names ca empty_data in
display_global_references deps;;
let display_dependance id =
let c = locate_reference (make_short_qualid id) in
match c with
VarRef _ -> assert false
| ConstRef cst ->
let cb = lookup_constant cst (env()) in
let c = match cb.const_body with Some c -> Declarations.force c
| _ -> failwith (string_of_id id ^ " has no value") in
display_global_references (collect_long_names c empty_data)
| IndRef i -> display_inductive i
| ConstructRef(i,k) -> display_inductive i;;
VERNAC COMMAND EXTEND Searchdepend
["SearchDepend" ident(id) ] ->
[ display_dependance id ; ]
END-custom "$(COQMKTOP) $(COQMKTOPFLAGS) -opt -o coqthmdep searchdepend.cmx"
searchdepend.cmx coqthmdep
COQMKTOP = coqmktop
searchdepend.ml
- [Coq-Club] The dependency graphs of Coq theorems, Hai WAN
- Re: [Coq-Club] The dependency graphs of Coq theorems, Yves Bertot
