- To: coq-club AT pauillac.inria.fr
- Subject: [Coq-Club] Partial Witness
- Date: Fri, 27 Feb 2009 16:05:37 +0000
Hello Everyone,
I was in contact with the Coq club recently to ask for help in finding the
proof
of a simple transformation. Being a Coq novice, I was very grateful for the help that I received. The solution to which I could most easily relate, was the one by Matthew Brecknell, i.e.
Record Process : Set := {PID : nat}.
Record Package : Set := {AID : nat}.
Theorem foo:
forall l : list Process, exists m : list Package,
forall p : Process, In p l -> exists a : Package,
In a m /\ PID p = AID a.
Proof.
induction l.
exists nil. unfold In. intros. elim H.
destruct IHl. exists (Build_Package (PID a) :: x). simpl. intros.
destruct H0.
exists (Build_Package (PID a)). split.
left. reflexivity.
rewrite H0. reflexivity.
destruct (H p H0). destruct H1. exists x0. split.
right. assumption.
assumption.
Qed.
I've successfully enhanced the specification (and the proof) on the input side, by adding a list field to the Process record, and I'd like to do the same on the output side with the Package record.
I've created a rather contrived example below to show you what I mean, by adding a list of numbers to each record, and a conjunct to assert the relationship between X and Y.
Require Import List.
Record Process : Set := {PID : nat; X : list nat}.
Record Package : Set := {AID : nat; Y : list nat}.
Theorem T :
In a m /\
PID p = AID a /\
forall n : nat, In n (X p) ->
n > 0 -> In n (Y a).
The problem is that at the stage in the proof where a witness is required for m (see proof below), I'm unable to fully specify one, because of the dependency of Y on X. I'm not sure whether this makes sense, but what I appear to need is a way of partially specifying a witness. Is this possible?
Any help would be gratefully appreciated.
Regards,
Jeff.
Welcome to Coq 8.2 (February 2009)
Coq < Require Import List.
Coq < Record Process : Set := {PID : nat; X : list nat}.
Process is defined
Process_rect is defined
Process_ind is defined
Process_rec is defined
PID is defined
X is defined
Coq < Record Package : Set := {AID : nat; Y : list nat}.
Package is defined
Package_rect is defined
Package_ind is defined
Package_rec is defined
AID is defined
Y is defined
Coq <
Coq < Theorem T :
Coq < forall l : list Process, exists m : list Package,
Coq < forall p : Process, In p l -> exists a : Package,
Coq < In a m /\
Coq < PID p = AID a /\
Coq < forall n : nat, In n (X p) ->
Coq < n > 0 -> In n (Y a).
1 subgoal
forall p : Process,
In p l ->
exists a : Package,
In a m /\
PID p = AID a /\ (forall n : nat, In n (X p) -> n > 0 -> In n (Y a))
T < induction l as [| p'].
2 subgoals
forall p : Process,
In p nil ->
exists a : Package,
In a m /\
subgoal 2 is:
forall p : Process,
In p (p' :: l) ->
exists a : Package,
In a m /\
T < exists nil.
2 subgoals
forall p : Process,
In p nil ->
exists a : Package,
In a nil /\
subgoal 2 is:
forall p : Process,
In p (p' :: l) ->
exists a : Package,
In a m /\
T < intros.
2 subgoals
p : Process
H : In p nil
exists a : Package,
In a nil /\
subgoal 2 is:
forall p : Process,
In p (p' :: l) ->
exists a : Package,
In a m /\
T < elim H.
1 subgoal
p' : Process
l : list Process
IHl : exists m : list Package,
forall p : Process,
In p l ->
exists a : Package,
In a m /\
PID p = AID a /\
forall p : Process,
In p (p' :: l) ->
exists a : Package,
In a m /\
T < destruct IHl as [mw].
1 subgoal
p' : Process
l : list Process
mw : list Package
H : forall p : Process,
In p l ->
exists a : Package,
In a mw /\
forall p : Process,
In p (p' :: l) ->
exists a : Package,
In a m /\
T < exists (Build_Package (PID p') ??????? :: mw).
- [Coq-Club] Simple Transformation, Jeff Terrell
- Re: [Coq-Club] Simple Transformation,
Matthew Brecknell
Jeff Terrell
- Re: [Coq-Club] Simple Transformation, Luke Palmer
Matthew Brecknell
Jeff Terrell
- Re: [Coq-Club] Simple Transformation, Adam Chlipala
- Re: [Coq-Club] Simple Transformation, Matthew Brecknell
- [Coq-Club] Partial Witness, Jeff Terrell
- Re: [Coq-Club] Partial Witness,
Adam Chlipala
Jeff Terrell
- Re: [Coq-Club] Partial Witness, Adam Chlipala
- Re: [Coq-Club] Partial Witness, Jeff Terrell
Jeff Terrell
Adam Chlipala
- Re: [Coq-Club] Partial Witness, Pierre Castéran
Jeff Terrell
Jeff Terrell
Matthew Brecknell
- <Possible follow-ups>
- Re: [Coq-Club] Simple Transformation, Roman Beslik
