- To: <coq-club AT pauillac.inria.fr>
- Subject: FW: [Coq-Club] Proving a proper sublist is smaller
- Date: Mon, 2 Mar 2009 11:54:29 -0700
Title: FW: [Coq-Club] Proving a proper sublist is smaller
-----Original Message-----
Sent: Mon 3/2/2009 11:50 AM
To: Nadeem Abdul Hamid
Subject: RE: [Coq-Club] Proving a proper sublist is smaller
If you are looking at list with no duplicates, then I think you should look at Laurent Thery's formulation of Sudoku in Coq (available at http://coq.inria.fr/contribs/Sudoku.html). In particular, you should look at Ulist.v which contains lemmas very similar to what you need.
Sunil
From: Nadeem Abdul Hamid [mailto:nadeem AT acm.org]
Sent: Mon 3/2/2009 11:47 AM
To: Luke Palmer
Cc: coq-club AT pauillac.inria.fr
Subject: Re: [Coq-Club] Proving a proper sublist is smaller
Yeah, that's problematic. :) OK, so perhaps I am missing some
additional assumptions in the statement of the lemma like (NoDup A),
(NoDup B)...
On Mar 2, 2009, at 1:44 PM, Luke Palmer wrote:
> On Mon, Mar 2, 2009 at 11:35 AM, Nadeem Abdul Hamid <nadeem AT acm.org>
> wrote:
> I'm having trouble figuring out how to prove the statement below.
> What it's saying is that if every element in list A is also in list
> B, and then you know that there is an additional element in list B
> that's not in list A, then the size of list B must
> be larger than A.
> You will always have trouble proving false theorems. :-)
> A = [1,1,1,2,3] ; B = [1,2,3,4]
> Luke
> Whether I try induction on A or B (with either rearranged to be
> first), I run into problems at the very end. Can someone help me
> figure out this puzzle, a different way to prove it than direct
> induction on A/B, or if there is a reason why it's not true?
> Lemma properSubset_smaller
> : forall (A B : list nat) (m:nat),
> (forall n, In n A -> In n B) ->
> In m B ->
> ~In m A ->
> length B > length A.
> Thanks very much,
> nadeem
> Bug reports: http://logical.saclay.inria.fr/coq-bugs
> Archives: http://pauillac.inria.fr/pipermail/coq-club
> http://pauillac.inria.fr/bin/wilma/coq-club
> Info: http://pauillac.inria.fr/mailman/listinfo/coq-club
- [Coq-Club] Proving a proper sublist is smaller, Nadeem Abdul Hamid
- Re: [Coq-Club] Proving a proper sublist is smaller,
Luke Palmer
Nadeem Abdul Hamid
- Message not available
- FW: [Coq-Club] Proving a proper sublist is smaller, Sunil Kothari
- Re: [Coq-Club] Proving a proper sublist is smaller, Luke Palmer
Nadeem Abdul Hamid
Luke Palmer
