coq-club - Re: [Coq-Club] Instantiating existential variables
chronological Thread
  • To: "Samuel E. Moelius III" <moelius AT cis.udel.edu>
  • Cc: coq-club AT pauillac.inria.fr
  • Subject: Re: [Coq-Club] Instantiating existential variables
  • Date: Sat, 07 Mar 2009 12:55:42 -0500
Samuel E. Moelius III wrote:
If I have an uninstantiated existential variable, is there a way to supply it interactively, as opposed to supplying it all-in-one-go via instantiate or Existential?
You can use the [evar] tactic to create new existentials, and then you can use [instantiate] to replace the old existential with a term that uses the new existentials. This doesn't tend to work out very smoothly, and generally it is a sign of a proof design flaw if you find yourself wanting to instantiate existentials explicitly. Good automation with [eauto] and friends tends to stamp out such troubles.
