- To: coq-club AT pauillac.inria.fr
- Subject: [Coq-Club] Problems with tail-recursion.
- Date: Thu, 12 Mar 2009 07:52:13 -0700 (PDT)
I was wondering if lemma1, lemma2 and lemma3 below were doable:
Thanks in advance.
Require Import List.
Require Import TheoryList.
Require Import Max.
Definition max_list (l : list nat) : nat := fold_left max l 0.
Inductive ST : Type :=
| arr : list ST -> ST.
Function order (s : ST) : nat :=
match s with
| arr sl => match sl with
| nil => 0
| _ => 1 + max_list (map order sl)
end
end.
Lemma compare_nat : forall (n m : nat), {n = m} + {n <> m}.
Proof.
Admitted.
Fixpoint find (ord : nat) (sl : list ST) (l : nat) {struct sl} : nat :=
match sl with
| nil => l
| s :: sl0 =>
if compare_nat (order s) ord then find ord sl0 (l + 1) else l
end.
Lemma lemma1 (ord : nat)(sl : list ST)(l : nat) :
find ord sl (S l) = S (find ord sl l).
Proof.
Admitted.
Lemma lemma2 (ord : nat)(s : ST)(sl : list ST)(H : order s = ord) :
find ord (s::sl) 0 = find ord sl 1.
Proof.
Admitted.
Lemma lemma3 (ord : nat)(s : ST)(sl : list ST)(H : order s = ord)(l : nat) :
find ord (s::sl) l = S (find ord sl l).
Proof.
Admitted.
View this message in context:
http://www.nabble.com/Problems-with-tail-recursion.-tp22477726p22477726.html
Sent from the Coq mailing list archive at Nabble.com.
- [Coq-Club] Problems with tail-recursion., dimitrisg7
- Re: [Coq-Club] Problems with tail-recursion.,
Edsko de Vries
- RE: [Coq-Club] Problems with tail-recursion.,
Dimitris Vekris
- Re: [Coq-Club] Problems with tail-recursion., Edsko de Vries
Cedric Auger
- Re: [Coq-Club] Problems with tail-recursion., Adam Chlipala
Dimitris Vekris
Edsko de Vries
