- To: <devriese AT cs.tcd.ie>
- Cc: <coq-club AT pauillac.inria.fr>
- Subject: RE: [Coq-Club] Problems with tail-recursion.
- Date: Thu, 12 Mar 2009 17:26:26 +0200
- Importance: Normal
Could you give me a hint cause i'm stuck? Lemma lemma1 (ord : nat)(sl : list ST)(l : nat) : find ord sl (S l) = S (find ord sl l). Proof. intros. induction sl; simpl. reflexivity. destruct (compare_nat (order a) ord). Admitted. Thanks for your help! > CC: coq-club AT pauillac.inria.fr > From: devriese AT cs.tcd.ie > To: dvekris AT hotmail.com > Subject: Re: [Coq-Club] Problems with tail-recursion. > Date: Thu, 12 Mar 2009 15:11:03 +0000 > > What's difficult about them? I tried lemma1 and lemma2, and they go > through easily enough. Where do you get stuck? > > (BTW, compare_nat is eq_nat_dec from the Arith library). > > Edsko What can you do with the new Windows Live? Find out |
- [Coq-Club] Problems with tail-recursion., dimitrisg7
- Re: [Coq-Club] Problems with tail-recursion.,
Edsko de Vries
- RE: [Coq-Club] Problems with tail-recursion., Dimitris Vekris
- Re: [Coq-Club] Problems with tail-recursion., Edsko de Vries
Cedric Auger
- Re: [Coq-Club] Problems with tail-recursion., Adam Chlipala
Edsko de Vries
