- From: "Samuel E. Moelius III" <moelius AT cis.udel.edu>
- To: Edsko de Vries <devriese AT cs.tcd.ie>
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] Simple question about tactic notation
- Date: Sun, 15 Mar 2009 13:38:26 -0400
It appears that, at the prompt, ``induction 2'' invokes the following version of ``induction'' from page 176 of the 8.2 reference manual.
18. simple induction num
This tactic behaves as intros until num; elim ident where ident is the
name given by intros until num to the num-th non-dependent premise of
the goal.
I don't know why the behavior is different in Ltac vs. at the prompt.
Also, I don't know why, at the prompt, Coq isn't insisting on the presence of ``simple''.
In any case, which did you intend: the standard ``induction term'' or ``simple induction num'' as above?
Sam
Edsko de Vries wrote:
Hi Sam,
If you change ``integer'' to ``constr'' in the definition of my_induction, then you no longer get the error.
Yes, the error disappears, and it seems to work, but appearances are deceiving
I think. Here's a slightly extended example:
Tactic Notation "my_induction" constr(n) :=
induction n.
Inductive even : nat -> Prop :=
| even_zero : even 0
| even_succ : forall n, even n -> even (S (S n)).
Inductive weird : nat -> Prop :=
| weird_0 : weird 0
| weird_1 : weird 1
| weird_2 : weird 2
| weird_3 : weird 3.
Lemma foo : forall (n:nat), even n -> weird n -> True.
Proof.
Now,
induction 2.
will do induction on 'weird n' (and give 4 subgoals). my_induction 2 however
will do induction on 'even n' (it seems its completely ignoring the argument);
Thomas's "solution" does the same (induction on 'even n').
Edsko
Bug reports: http://logical.saclay.inria.fr/coq-bugs
Archives: http://pauillac.inria.fr/pipermail/coq-club
http://pauillac.inria.fr/bin/wilma/coq-club
Info: http://pauillac.inria.fr/mailman/listinfo/coq-club
- [Coq-Club] Simple question about tactic notation, Edsko de Vries
- Re: [Coq-Club] Simple question about tactic notation,
Thomas Braibant
Edsko de Vries
- Re: [Coq-Club] Simple question about tactic notation, Samuel E. Moelius III
- Re: [Coq-Club] Simple question about tactic notation, Edsko de Vries
Edsko de Vries
Edsko de Vries
- Re: [Coq-Club] Simple question about tactic notation, Hugo Herbelin
Thomas Braibant
