coq-club - [Coq-Club] Working with the Equivalence type class
chronological Thread
  • To: coq-club AT pauillac.inria.fr
  • Subject: [Coq-Club] Working with the Equivalence type class
  • Date: Thu, 19 Mar 2009 17:28:40 -0400
Hi all,
I'm curious why some things work and why others don't when using the
Equivalence type class (from Coq.Classes.Equivalence).  My typical uses
of the class arise indirectly, via EqDec, so I'll give a simple example
using EqDec.
Require Import Coq.Classes.EquivDec.
Lemma test : forall `(EqDec A eq) (x y : A), y = x \/ y <> x.
Proof.
  intros ? ? ? x y.
  destruct (x == y) as [J | J].
At this point, the first subgoal looks as follows
  A : Type
  equiv0 : Equivalence eq
  H : EqDec A eq
  x : A
  y : A
  J : x === y
   y = x \/ y <> x
[rewrite J] works, which is great.
[left; congruence] works, which is also great.
[subst x] fails, which is not so great.
Is there a simple explanation for the behavior of these tactics in this
particular situation?  When the equivalence relation I work with is
[eq], as it is in the above example, it would be nice if "===" was
treated the same as "=".
Thanks,
Brian
