- From: Pierre Letouzey <Pierre.Letouzey AT pps.jussieu.fr>
- To: "M. Scott Doerrie" <mdoerri AT cs.jhu.edu>
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] FSet Extensionality Not defined
- Date: Wed, 18 Mar 2009 20:03:43 +0100
On Wed, Mar 18, 2009 at 02:20:36PM -0400, M. Scott Doerrie wrote:
> I would really like to have an axiom-free method of constructing
> Ensembles from FSets. However, I can't find any definition for
> Extensionality_Ensembles in FSetToFiniteSet in any version of the Coq
> standard library. I believe this axiom would be derivable if creating
> FSets from UsualOrderedTypes, yet I can not locate it. Did I miss
> something? Is this not possible?
> Scott Doerrie
No, having Leibniz equality on the elements is not enough to have the
extensionnality of finite sets in all generality. For instance, take a
tree-based implementation (typically AVL): there are many ways to
balance a tree while keeping the same elements in it.
It remains me an old question on this topic, but I can't find back the
precise thread on coq-club. Anyway, to illustre my answer at that
time, I wrote a small file FSetListEq.v, still accessible via:
svn://scm.gforge.inria.fr/svn/coq-contribs/trunk/Orsay/FSets/FSetListEq.v
As said in a comment at the start of the file:
(* For the equality on sets to be the one of Coq, we need:
- an order on elements, and not just a decidable equality
(hence an OrdereredType leading to some FSets instead of
a DecidableType leading to some FSetWeak).
- the equality on elements must be the one of Coq
(hence a UsualOrderedType instead of just a OrderedType)
- an implementation of sets with canonical representation,
for instance FSetList based on sorted lists.
- the proof irrelevance axiom, since an implementation such
as FSetList isn't really canonical: a set comes with
a well-sortedness certificate.
Best,
Pierre
- Re: [Coq-Club] FSet Extensionality Not defined, (continued)
Stéphane Lescuyer
M. Scott Doerrie
Adam Chlipala
- Re: [Coq-Club] FSet Extensionality Not defined, Bruno Barras
Stéphane Lescuyer
M. Scott Doerrie
Stéphane Lescuyer
- Re: [Coq-Club] FSet Extensionality Not defined, M. Scott Doerrie
- Re: [Coq-Club] FSet Extensionality Not defined, Adam Chlipala
Stéphane Lescuyer
M. Scott Doerrie
- RE: [Coq-Club] FSet Extensionality Not defined, Georges Gonthier
Adam Chlipala
M. Scott Doerrie
- Re: [Coq-Club] FSet Extensionality Not defined, Pierre Letouzey
Stéphane Lescuyer
