coq-club - [Coq-Club] Hints and Inline parameters in Module Types
chronological Thread
  • To: coq-club AT pauillac.inria.fr
  • Subject: [Coq-Club] Hints and Inline parameters in Module Types
  • Date: Fri, 20 Mar 2009 11:43:30 -0400
Hi all,
In Coq 8.2, the [eq] and [t] fields of the [DecidableType] module type
were declared as "Inline".  I'm not sure how "Inline" is supposed to
work, especially with respect to hint declarations, so I pose below as
simple an example as I can come up with.
First, I have some basic set up code.  I'm specifically interested in
what gets added to the core hint database when the functors below are
instantiated.
  Require Import DecidableType.
  Require Import DecidableTypeEx.
  Require Import FSets.
  Module Functor_fun (E : DecidableType) (Import M : WSfun E).
    Hint Resolve E.eq_refl.
  End Functor_fun.
  Module Functor (M : WS) := Functor_fun M.E M.
With those definitions in hand, I try the following.
  Module Impl := FSetWeakList.Make Nat_as_DT.
  Module Import X1 := Functor Impl.
  Print HintDb core.
Here, [eq_refl] shows up only as a hint for [Nat_as_OT.eq].  Given the
"Inline" declaration in [DecidableType], I would have expected [eq_refl]
to show up as a hint for [eq].
  Module Import X2 := Functor_fun Impl.E Impl.
  Print HintDb core.
Now, [eq_refl] shows up as a hint for [eq].
Appearances suggest to me that the functor instantiations for [X1] and
[X2] should do the same thing, but apparently there is some difference.
 Is this intended to be the case?  What's the difference?
Thanks for any clarification,
Brian
