- To: hugo.herbelin AT inria.fr, coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] C-zar proof help
- Date: Fri, 20 Mar 2009 13:08:29 +0000
On Friday 20 March 2009 11:04:45
wrote:
> Hi,
> On Fri, Mar 20, 2009 at 01:02:17AM +0000, Ian Lynagh wrote:
> > Assertion failure? Luxury! I just get segfaults when coq disagrees with
> > me:
> > https://logical.saclay.inria.fr/coq-bugs/show_bug.cgi?id=2081
> > https://logical.saclay.inria.fr/coq-bugs/show_bug.cgi?id=2064
> > I religiously save before running anything in coqide now...
> Most causes of segmentation fault in Coq are due to stack overflows
> that are most often fatal in native Objective Caml code (even with
> recent versions of O'Caml) and against which we don't know any kind of
> reasonable protection. This is especially the case of the bug reports
> #2064 and #1809.
I run into stack overflows often when calling vm_compute on goals that
generate
large terms e.g. 5000 * 5000. Is there anything that can be done to stop Coq
from causing a segmentation fault in such cases? I would find a function (in
OCaml or a Coq tactic) that tries to reduce a term but gives up if it grows
too big to be useful here.
Regards,
Sean
- Re: [Coq-Club] C-zar proof help, (continued)
Taral
Taral
Ian Lynagh
Taral
Ian Lynagh
Taral
- Re: [Coq-Club] C-zar proof help, Ian Lynagh
- Re: [Coq-Club] C-zar proof help, Hugo Herbelin
- Re: [Coq-Club] C-zar proof help, Pierre Corbineau
- Re: [Coq-Club] C-zar proof help, Sean Wilson
Taral
Ian Lynagh
Taral
Pierre Corbineau
- Re: [Coq-Club] C-zar proof help, Taral
Ian Lynagh
Taral
Taral
