- From: Florian Haftmann <florian.haftmann AT informatik.tu-muenchen.de>
- To: coq-club AT pauillac.inria.fr
- Subject: [Coq-Club] Cezar proof text transformation
- Date: Wed, 25 Mar 2009 10:11:23 +0100
- Organization: TU München, Lehrstuhl Software an d Systems Engineering
Dear all,
for demonstration purpose I am currently tinkering around with Cezar
(current coq release 8.2) using some simple propositions.
At one stage I run into a problem of understanding; I have the
following proof fragment (see below for the full example):
focus on (S q + s = n). escape.
rewrite n_Sr. simpl. rewrite qsr. reflexivity.
return. end focus.
According to my understanding of Cezar this could also be written as
thus (S q + s = n)
using rewrite n_Sr; simpl; rewrite qsr; reflexivity.
However this is rejected as insufficient justification.
What am I missing?
Any help appreciated,
Florian
Require Import Arith.
Theorem le_Sm_n_pred:
forall m n: nat, S m <= n -> { q : nat | S q = n }.
proof.
let m: nat, n: nat.
per cases on n.
suppose it is 0.
assume (S m <= 0).
hence thesis by (le_Sn_O m).
suppose it is (S q).
thus thesis using exists q; reflexivity.
end cases.
end proof. Qed.
Theorem exists_minus:
forall m n: nat, m <= n -> { q : nat | m + q = n }.
proof.
let m: nat.
per induction on m.
suppose it is 0.
let n: nat.
thus thesis using simpl; exists n; reflexivity.
suppose it is (S q) and hyp: thesis for q.
let n: nat.
assume Sq_n: (S q <= n).
then ex_r: {r : nat | S r = n} by (le_Sm_n_pred q n).
consider r such that (S r = n) from ex_r.
then n_Sr: (n = S r).
then (S q <= S r) by Sq_n.
then (q <= r).
then ex_s: {s : nat | q + s = r} by hyp.
consider s such that qsr: (q + s = r) from ex_s.
(* the following works *)
return. end focus.
(* this more concise version refuses to work:
thus (S q + s = n)
end induction.
end proof. Qed.
Home:
http://wwwbroy.in.tum.de/~haftmann
PGP available:
http://home.informatik.tu-muenchen.de/haftmann/pgp/florian_haftmann_at_informatik_tu_muenchen_de
signature.asc
Description: OpenPGP digital signature
- [Coq-Club] Cezar proof text transformation, Florian Haftmann
- Re: [Coq-Club] Cezar proof text transformation,
Taral
Florian Haftmann
Taral
- Re: [Coq-Club] Cezar proof text transformation, Florian Haftmann
Taral
Florian Haftmann
Taral
