coq-club - Re: [Coq-Club] Cezar proof text transformation
chronological Thread
  • From: Florian Haftmann <florian.haftmann AT informatik.tu-muenchen.de>
  • To: Taral <taralx AT gmail.com>, coq-club AT pauillac.inria.fr
  • Subject: Re: [Coq-Club] Cezar proof text transformation
  • Date: Sat, 28 Mar 2009 15:09:01 +0100
  • Organization: TU München, Lehrstuhl Software and Systems Engineering
Hi Taral,
> Set Ltac Debug.
> This will show you the actual environment under which your "using ..."
> clause is being run. It is *not* the same as the (full) environment
> you get with "escape".
indeed it works the following way:
thus (S q + s = n) by n_Sr, plus_Sn_m, qsr.
The rule plus_Sn_m has to named explicitly.
Thanks a lot!
        Florian
Home:
http://wwwbroy.in.tum.de/~haftmann
PGP available:
http://home.informatik.tu-muenchen.de/haftmann/pgp/florian_haftmann_at_informatik_tu_muenchen_de
Attachment: signature.asc
Description: OpenPGP digital signature
