coq-club - Re: [Coq-Club] Needed assistance in Coq proof for kleene algebra axioms
chronological Thread
  • To: prateek agarwal <prat0318 AT gmail.com>
  • Cc: coq-club AT pauillac.inria.fr
  • Subject: Re: [Coq-Club] Needed assistance in Coq proof for kleene algebra axioms
  • Date: Tue, 31 Mar 2009 10:12:46 -0400
prateek agarwal wrote:
        If anyone has the coq proofs for the axioms of Kleene algebra
and Kleene algebra Tests, I shall be grateful if you could please
provide them to me. Or, I am having a short coq code written for their
proofs, but an error in compilation occurs in lines where ~ and #
symbols are used. I am a newbie in COQ, can anyone please sort out the
error.
<snippet from ka.v>...
Record boolean_theory : Prop := mk_bool {
ba_ax_1 : forall x, x * ~x = 0 ;
Error : The term "0" has the type "nat" while it is expected to have type
"Set".
You seem to be trying to treat Coq's logic as untyped, which it isn't. Unless you explicitly introduce overrides of the standard notations, [0] always means natural-number zero, [*] always means natural-number multiplication, etc.. Each of your theory records should contain the [Set] being operated on, along with the constant and operator definitions, and the logical members of the record should refer to those operators, not some fixed set of operators, which can't be "polymorphic enough." (There may be alternate ways of doing this with the newfangled type class support, but I don't know that stuff well enough to say.)
