coq-club - Re: [Coq-Club] families of sets extension
chronological Thread
  • To: James McKinna <james.mckinna AT cs.ru.nl>
  • Cc: St�phane Lescuyer <lescuyer AT lri.fr>, Edsko de Vries <devriese AT cs.tcd.ie>, Julien Forest <forest AT ensiie.fr>, anabelcesar <anabelcesar AT gmail.com>, coq-club AT pauillac.inria.fr, Andrew Ireland <a.ireland AT hw.ac.uk>
  • Subject: Re: [Coq-Club] families of sets extension
  • Date: Tue, 31 Mar 2009 14:48:44 +0100
On Monday 30 March 2009 15:45:38 James McKinna wrote:
> Dear Edsko, and others,
> a simpler example might be to try to show, for example, commutativity of
> addition on natural numbers defined tail-recursively as
> plus 0 n = n
> plus (S m) n = plus m (S n)
> We discussed this problem (and automatic techniques for solving it, due
> to Andrew Ireland and Alan Bundy in particular) at the Dagstuhl 9350
> meeting in 1995...
>     http://www.dagstuhl.de/en/program/calendar/semhp/?semnr=9530
> But I can't find Andrew's paper on it out there in TV-land ("Rippling to
> meet the challenge", I think it was called, given during the last
> session on challenge problems). You might check with him directly...
I couldn't find the paper, but I've been implementing a rippling tactic in
Coq
(I hope to release this soon) and it can automatically prove commutativity of
addition using the tail-recursive definition of plus above. It can do this
given only the definition of plus and the regular induction principles
generated by Coq. A manual proof that imitates the proof steps the rippling
tactic makes in one of its proofs is as follows:
Fixpoint plus_t (m n : nat) {struct m} : nat :=
  match m with
  | 0 => n
  | S p => plus_t p (S n)
  end.
Notation "x +t y" := (plus_t x y) (at level 20).
Theorem add_commute_2 : forall a b, a +t b = b +t a.
intros.
revert a.
induction b.
 simpl.
 induction a.
  reflexivity.
  rewrite <- IHa.
  generalize (a +t 0). intros. clear.
  induction n.
   reflexivity.
   simpl.
   rewrite <- IHn.
   generalize 0. intros. clear.
   revert n0.
   induction n.
    reflexivity.
    simpl.
    intros.
    rewrite IHn.
    reflexivity.
 intros.
 simpl.
 rewrite <- IHb.
 reflexivity.
Defined.
The essentially tricks are to make use of "revert" and "generalize" where
appropriate before performing induction so that the induction hypotheses are
strong enough in the step cases. I found that the "generalize 0" step in one
of the subgoals wasn't obvious i.e. n +t 2 = S (S n +t 0) should be
generalized to n +t S (S n0) = S (S n +t n0) before induction is performed on
n. There are a couple of papers on my homepage that briefly describe
automation with rippling in Coq: http://homepages.inf.ed.ac.uk/s0091720/
Regards,
Sean
