- To: "coq-club AT pauillac.inria.fr" <coq-club AT pauillac.inria.fr>
- Subject: RE: [Coq-Club] Sorting
- Date: Sat, 11 Apr 2009 22:45:40 +0100
- Accept-language: en-US
- Acceptlanguage: en-US
> http://coq.inria.fr/V8.2/doc/html/stdlib/Coq.Sorting.Sorting.html
> This library provides a merge function over two sorted lists, but
> there is still some work to do to implement mergesort. See:
> http://gallium.inria.fr/~xleroy/coq/Mergesort.html
> http://gallium.inria.fr/~xleroy/coq/Mergesort.v
> It's a nice exercise in using "Program".
It's also possible to manage without Program; e.g., the ssreflect library
uses the code below (replace seq by list and expand list notations to
interface with the Coq standard library) -- enjoy.
- Georges Gonthier
Fixpoint merge_sort_push (s1 : seq T) (ss : seq (seq T)) {struct ss} :=
match ss with
| nil :: ss' | nil as ss' => s1 :: ss'
| s2 :: ss' => nil :: merge_sort_push (merge s1 s2) ss'
end.
Fixpoint merge_sort_pop (s1 : seq T) (ss : seq (seq T)) {struct ss} :=
if ss is s2 :: ss' then merge_sort_pop (merge s1 s2) ss' else s1.
Fixpoint merge_sort_rec (ss : seq (seq T)) (s : seq T) {struct s} :=
if s is [:: x1, x2 & s'] then
let s1 := if leT x1 x2 then [:: x1; x2] else [:: x2; x1] in
merge_sort_rec (merge_sort_push s1 ss) s'
else merge_sort_pop s ss.
Definition sort := merge_sort_rec [::].
- [Coq-Club] Sorting, dimitrisg7
- Re: [Coq-Club] Sorting,
Taral
Xavier Leroy
- Re: [Coq-Club] Sorting, Adam Koprowski
- RE: [Coq-Club] Sorting, Georges Gonthier
Xavier Leroy
Taral
