coq-club - Re: [Coq-Club] Problem with modules
chronological Thread
  • To: Ian Lynagh <igloo AT earth.li>
  • Cc: coq-club AT pauillac.inria.fr
  • Subject: Re: [Coq-Club] Problem with modules
  • Date: Fri, 17 Apr 2009 16:04:08 -0400
On Apr 17, 2009, at 12:22 PM, Ian Lynagh wrote:
I'm having trouble with coq's module system, and I can't work out what
the right solution is.
Right now, your files seem to take the following form: For a file named foo.v, you have
        Module Export foo.
        Load bar.
        Load baz.
        (* Lots of Coq. *)
        End foo.
I believe the more idiomatic form of what you want is to have the following in foo.v:
        Require Import bar.  (* or Require Export bar. *)
        Require Import baz.  (* or Require Export baz. *)
        (* Lots of Coq. *)
This is the natural way (in my opinion) of treating foo.v as one compilation unit / one library file. [Require Import bar] has the effect of making the definitions in bar available in the remainder of the current file, and you can refer to those definitions without the need for qualified names. (This does require, however, that bar has been compiled to a .vo file using coqc.) This is how Coq's standard library is implemented, and it might be a good source of examples.
I believe [Load] works as if it takes the named file and cuts-and- pastes its contents into the current file at the specified location. This probably explains why you're getting multiple definitions of the same thing.
[Module foo ... End foo] concerns Coq's module system. I tend to think of this as something separate from treating a file as a library.
I hope that helps,
Brian
