- To: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] Problem with modules
- Date: Sat, 18 Apr 2009 16:54:38 +0100
On Fri, Apr 17, 2009 at 04:04:08PM -0400, Brian Aydemir wrote:
> I believe the more idiomatic form of what you want is to have the
> following in foo.v:
> Require Import bar. (* or Require Export bar. *)
Thanks, I have something working now.
> the current file, and you can refer to those definitions without the
> need for qualified names. (This does require, however, that bar has
> been compiled to a .vo file using coqc.)
Yes, that's why I was using Load; I assumed that it was the same as
Require Import, except loading from the .v rather than .vo.
I am worried I will get confused by out-of-date dependencies now; I
would be much happier if coqide had a run-coqc-if-out-of-date option.
> [Module foo ... End foo] concerns Coq's module system. I tend to
> think of this as something separate from treating a file as a library.
I'm using Module rather than Section as coq wouldn't let me put
Module DecidableName.
Definition t := Name.
Definition eq := @eq Name.
Definition eq_refl := @refl_equal Name.
Definition eq_sym := @sym_eq Name.
Definition eq_trans := @trans_eq Name.
Definition eq_dec := eq_Name_dec.
End DecidableName.
Module NameSet := Make(DecidableName).
inside a Section. And if I use neither Module nor Section then everyone
in #coq tells me off :-)
Thanks
Ian
- [Coq-Club] Problem with modules, Ian Lynagh
- Re: [Coq-Club] Problem with modules,
Brian Aydemir
- Re: [Coq-Club] Problem with modules, Ian Lynagh
Brian Aydemir
